Camaro leaked gas - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 8th, 18, 07:26 PM Thread Starter
Probationer
Camaro leaked gas
Hello, today my 68 Camaro leaked gas when I started it. It has done this one before, a year ago. It had been sitting for a month plus and did not leak after I drove off. Any ideas?
The engine is a crate motor 350ci/350hp with an Edelbrock EFI (Electronic Fuel Injection), Speed Pro Pistons, Comp Cam and lifters, Turbo 350 automatic trans with horseshoe shifter, Mallory HEI ignition, Edelbrock ceramic coated headers, Flowmasters, 10 bolt (non-posi), power steering, power 4 wheel disc brakes, HD Tri-Core radiator, ice cold vintage Air A/C System, Power Windows, Tilt Wheel, Full Guages, Eagle Alloys with
Rocky Citti is offline
post #2 of 6 (permalink) Old Oct 8th, 18, 07:57 PM
keith
X-77 keith's Avatar
Need more info. Where is it leaking? Rear of the car? Middle of the car? Engine bay? This will help you get possible answers.
X-77 keith
X-77 keith is offline
post #3 of 6 (permalink) Old Oct 8th, 18, 08:58 PM Thread Starter
Probationer
Re: Camaro leaked gas
From the gas tank underneath the car.
Sent from my iPhone using Tapatalk
post #4 of 6 (permalink) Old Oct 8th, 18, 09:18 PM
Darin
ilikeike's Avatar
You probably need to get under the car and look at the area you see wet with fuel.
I’m sure you’ll easily see the leak and what you’ll need to fix.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #5 of 6 (permalink) Old Oct 9th, 18, 03:31 AM
Apprentice
Bob
Check all visible connections for leaks.Next drain and drop the tank and inspect hoses, sending unit seal and for cracks on the tank.I had a problem in which someone had installed the incorrect sending unit which required a return line and pinched and put epoxy at the end.My car has only one line.After owning the car for a couple of years it started leaking from the top of the tank.Dropped tank and installed the correct sending unit.
tuxedoblack is offline
post #6 of 6 (permalink) Old Oct 9th, 18, 08:04 AM
Replace all rubber non fuel injection hoses if your using ethanol gas. Ethanol eats the OEM type lines from that era.
COPO is offline
