what is this knocking noise? - 350 SBC - Team Camaro Tech
 1Likes
  • 1 Post By 68basecoupe
post #1 of 13 (permalink) Old Oct 28th, 18, 07:01 PM Thread Starter
Tony
Ghostbuster's Avatar
Unhappy what is this knocking noise? - 350 SBC
My buddy has this SBC 350. The engine starts, idles and runs fine, but it has a nasty knocking sound under heavy load/acceleration. Compression was 110-115# in 6 or 8 cyl, (couldn't access the last 2 due to header placement). I need some ideas. Any questions or suggestions to help narrow this down would be greatly appreciated.
I got an error watching the video on this site, but it plays fine on youtube.
Copy and paste these links into your browser, (minus quotes).
"https://youtu.be/LSffr0O7SB4"
"https://youtu.be/Eq62Eexs_DI"
1968 Z/28 Convertible
1969 RS/SS Coupe (vinyl top & Sunroof)
2011 RS/SS Convertible
Ghostbuster is offline
post #2 of 13 (permalink) Old Oct 28th, 18, 07:09 PM
Re: what is this knocking noise? - 350 SBC
I’m gonna guess wiped cam lobe(s) but there are folks on here that are a lot smarter diagnosing this sort of thing than me.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 13 (permalink) Old Oct 29th, 18, 05:08 AM
kevin
when the cam went on mine it did not want to idle properly
easiest is to pull the valve covers and spin the engine and watch the valve, spring function
drain the oil in a clean container and examine it. cut open the oil filter. if there are particles that stick to a magnet, probably cam and or lifters. nonmetallic - bearings
flat tire is offline
post #4 of 13 (permalink) Old Oct 29th, 18, 07:28 AM
Travis
I had a cracked flex plate once that sounded like a knock under acceleration/load and idle to some degree. Many people listened to the sound and thought rod, wrist pin, cam ect.
I pulled up to a shop in San Diego and an old man in a rocking chair sitting out front told me to get my flexplate replaced as I stepped out of the car.
Tough to see the flex plate in the car so I'd start with the easy things....compression check on all 8, cut filter open and check for particles or maybe use a stethoscope to narrow down the origin of the sound.
travisch is offline
post #5 of 13 (permalink) Old Oct 29th, 18, 07:31 AM
Vega$69's Avatar
Guessing wiped lobe. Listen with a mechanics stethoscope at the valve covers and/or pull the valve cover and check the rockers
Vega$69 is offline
post #6 of 13 (permalink) Old Oct 29th, 18, 08:27 AM
Certainly sounds like valve train. He may simply have a bad lifter. Use a stethoscope as John suggested to try and isolate the cylinder. A wiped lobe is normally noticeable at idle.
my 67' build thread:
allanjs is offline
post #7 of 13 (permalink) Old Oct 31st, 18, 06:46 PM
If it's the cam I'd bet on number 8.
1968 Z-28 Black stripes on white, 350, M22, 12bolt. WIP since August 1979
jimnecci is offline
post #8 of 13 (permalink) Old Oct 31st, 18, 07:50 PM
scott
68basecoupe's Avatar
What is the “canister” to the left of the distributor in the second video that appears to really vibrate when it’s making the noise and stops when the noise seems to go away
Orange_Z10 likes this.
68basecoupe is offline
post #9 of 13 (permalink) Old Nov 1st, 18, 03:00 PM
George
Looks like a possible add-on cruise control? My guess is also valve train related, even a possible bad valve spring, cam, lifter, or rocker stud, as others have suggested.
67 RS Ragtop is offline
post #10 of 13 (permalink) Old Nov 2nd, 18, 04:14 PM Thread Starter
Tony
Very good George, that is correct, it's an after market cruise control.
We disconnected that item from throttle/vacuum and no change to the knocking under load sound.
I appreciate all the input from everyone, I was hoping it was something simple, it never is..
post #11 of 13 (permalink) Old Nov 3rd, 18, 01:01 PM
Chuck
Orange_Z10's Avatar
That's exactly what I think it is. The mystery canister vibrating and making contact with something.
Orange_Z10 is offline
post #12 of 13 (permalink) Old Apr 27th, 19, 11:55 AM Thread Starter
Tony
Turns out that cyl#3 was loosing compression, exhaust valve not seating completely. I'm told the noise under load, was detonation with the exhaust port open slightly. Time for a valve job on this 350.
Thanks to everyone who posted their thoughts on this problem.
post #13 of 13 (permalink) Old Apr 28th, 19, 08:55 AM
When I lost 3 lobes on my solid lifter cam, it made no noises what so ever, just popping through the carb at 5,000 rpm due to having both intake and exhaust lobes gone.
COPO is offline
