Bad Relay Switch???????????????????? - Team Camaro Tech
post #1 of 3 (permalink) Old May 10th, 05, 06:16 AM Thread Starter
Question Bad Relay Switch????????????????????
With the ignition in the "on" position and i turn the steering wheel left or right there is a "clicking" sound at the relay switch. Also when i connect the horn and put the turn signal in the left or right turn position the horn blows. Is my relay switch bad and this may be causing my other problems? Any help is appreciated thanx.
73'camaro,350/400hp,muncie m-21,hurst comp plus,richmond 3.73 posi 10-bolt 8.5
libb58 is offline
post #2 of 3 (permalink) Old May 10th, 05, 06:49 AM
Harry
dawg's Avatar
Re: Bad Relay Switch????????????????????
probably the ignition switch.
or turn signal switch
434 stroker
US Navy retired
dawg is offline
post #3 of 3 (permalink) Old May 10th, 05, 08:07 AM
Check your ground! Make sure you have a good ground from the battery to the passenger fender. I've reproduced this exact problem when I didn't have the radiator support grounded properly via the fender.
and
Brian Lewis is offline
'69 Horn Question redlines4us Electrical & Wiring 39 Jun 10th, 09 11:31 AM
68 or 69 AC relay switch Black69 Electrical & Wiring 6 Aug 15th, 04 12:32 PM
AC relay switch Black69 Troubleshooting 1 Aug 12th, 04 01:17 PM
67 rs headlights 19673L4P Electrical & Wiring 6 Jun 23rd, 04 02:55 PM
RS Relay Vacuum Switch Indy Z11 Restoration Corner 3 Jun 4th, 04 02:22 PM
