car starts and run for 15-20mins then cuts off - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 31st, 05, 08:54 AM Thread Starter
Unhappy car starts and run for 15-20mins then cuts off
i have taken this car to 3 shops. no one can solve this problem. my car starts and run for 15-20 mins then shut down but will start back up. it only does this at red lights and stop signs. have check computer,iac,module... don't have no clue. Please help with promblem
goldyiroc is offline
post #2 of 7 (permalink) Old Dec 31st, 05, 10:06 AM
Re: car starts and run for 15-20mins then cuts off
I presume the car is an IROC based on your userID. Sounds like whateve it is, the problem occurrs when the car enters closed-loop mode.
Is the check engine light comming on? Have any of the 3 shops managed to extract error codes from the ECM - if so what are they? Does the car shutter and cough after 15-20 minutes, or just shut down as if the key was turned off?
Give us a little more info on the car like the year, engine size, when did this problem start, etc.
dnult is offline
post #3 of 7 (permalink) Old Jan 1st, 06, 11:26 AM Thread Starter
it's a 89 iroc. the problem started between changing the fuel pump and then it was not staying crunk. so between taking it to the shop and so call mechanics looking at it. i replace a lot of parts like dis.iac,. when i took it to a shop. they replace the computer then it would run but shut off. now that's where i am at this point.
post #4 of 7 (permalink) Old Jan 17th, 06, 07:37 PM
try the ignition module. soon you're car will only run when it wants to. just a thought!!!! its the black box under yur distributer.
chadrafuse is offline
post #5 of 7 (permalink) Old Jan 17th, 06, 07:58 PM
Lost track of this thread Goldy, what's the status?
dnult is offline
post #6 of 7 (permalink) Old Jan 17th, 06, 08:09 PM
sorry i never read it through. disregard my comment...ooops
post #7 of 7 (permalink) Old Jan 19th, 06, 09:07 PM
wdf
take car to a good shop with scanner thst can "snap shot " data/ best way to find a heat soak intermittant. (closed loop is much before this area)
wdf is offline
