68 RS Hidden headlight Hissing New System - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 10th, 06, 08:15 PM Thread Starter
I just replaced my complete hidden headlight system,
Actuator
Hoses (all new)
Tanks (lower)
WHen i shut my car off i hear a small hiss/leak around the new actuator i just bought from classic, Is this normal, do these bleed off some of the vacuum once the car is turned off? or is this an indication of a defective part.
Thanks 68camrs
68camrs is offline
post #2 of 8 (permalink) Old Jan 11th, 06, 03:14 PM
click's Avatar
Re: 68 RS Hidden headlight Hissing New System
it shouldnt hiss but actually hold vac for awhile if everything is tight. The valve on top of the vac tank might have a leak in it. put some Dawn dishsoap and water around all the connections and all over the valve and see if you can see bubbles or air movement. Then you found your source.
click is offline
post #3 of 8 (permalink) Old Jan 11th, 06, 05:40 PM
ralph
if you can hear it hissing just listen an you will finf it
west 68 is offline
post #4 of 8 (permalink) Old Jan 11th, 06, 06:43 PM Thread Starter
I tracked down the hissing sound. It is clearly coming from the very bottom of the new relay switch. Question - is this normal. When i place my finger on the bottom of the valve, engine on,i can remove my finger and there is clearly a vacuum created. When i shut the car off, i can monitor the hissing in the same manner until the vacuum is depleted. Help greatly appreciated on this before any return warrenty runs out. Thanks.
68camrs is offline
post #5 of 8 (permalink) Old Jan 11th, 06, 07:12 PM
click's Avatar
It shouldnt leak like that. It should hold Vacuum while driving or when shut down for a short time too. If its a repo, send it back. That relay has been known to have problems as others have reported in here over the years too.
click is offline
post #6 of 8 (permalink) Old Jan 19th, 06, 06:38 PM Thread Starter
Thanks everyone. Replacement part arrrived and installed. No hissing. System even holds a vacuum after car is off for awhile. Imagine that. Thanks again. 68camrs.
68camrs is offline
post #7 of 8 (permalink) Old Jan 28th, 06, 04:15 PM
I've thought of replacing my system. Is it worth the expense and effort?
68fan is offline
post #8 of 8 (permalink) Old Feb 1st, 06, 09:42 AM Thread Starter
I think so. as i recall, hoses, lower vacuum acutators, and relay(i broke mine being dumb and not realizing how brittle the plasitc was) came to about $300. One actuator was bad, but i decided to replace both while the project was fresh in my mind. As i am not that talented with the more advanced stuff, i got a real sense of accomplishment on this project. Good Luck.
68camrs is offline
