oil pressure - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 13th, 06, 08:11 AM Thread Starter
Robert
oil pressure
just a quick question, i've got a 350 sb in a 69 camaro, I have good pressure while cruising (50psi) but at idle this drops to 15 psi, the guage is a mechanical autometer. Is this normal? thanks in advance for replies.
We do not possess imagination enough to sense what we are missing.
robert68 is offline
post #2 of 7 (permalink) Old Jan 13th, 06, 08:23 AM
Robert
Re: oil pressure
Assuming the engine is warm I'd say it's good.
Robert
TC member #18
rojo is offline
post #3 of 7 (permalink) Old Jan 13th, 06, 08:26 AM
Wes
Re: oil pressure
Agree,..you're fine. If you'd like to see more pressure at warm idle you could switch to 10-40 (assuming you're using 10-30).
Straight-line-69 is offline
post #4 of 7 (permalink) Old Jan 13th, 06, 11:05 AM Thread Starter
Robert
Re: oil pressure
currently using 5-30 mobile 1, thanks for the replies
robert68 is offline
post #5 of 7 (permalink) Old Jan 13th, 06, 11:39 AM
Chris
Cool Re: oil pressure
A minimum of about 12 psi at idle (550-750 RPM) is okay. The thinner the oil is the lower the pressure will be. I think your okay. If that is an old style 350 SBC, I would change to 10W-30 or 15W-40 Mobil 1. 5W-30 Mobil 1 is for newer engines.
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #6 of 7 (permalink) Old Jan 13th, 06, 07:19 PM
wdf
Re: oil pressure
a small block will live with as little as 1 psi /100 rpm at idle EG 500rpm=5psi
yes i would like more also.
wdf is offline
post #7 of 7 (permalink) Old Jan 14th, 06, 06:08 AM
Brad
RS3SDL2MG's Avatar
Re: oil pressure
oil pressure is fine but ditch the 5-30 from the camaro ,
use the 5-30 in your mini van LOL!!!
in the heat of summer I use 20-50 in my camaro
1967 RS 327
RS3SDL2MG is offline
