No dash lights/inter horn on while running - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 14th, 06, 03:20 PM Thread Starter
I have no dash lights at all.
My turn sign work but does not shom on the dash.
The cig lighter does not work either.
When I turn the key to start oil press, alt, or temp light does not come on.
Also the horn that sounds when you leave the door open with the key in the ing or the lights on sounds continuly while the car is running.
It does stop sounding withe the doors closed but when I start the car iit never shuts off.
I have checked all the fuses and they are all good.
I also have conected and diconected every rely I could get my hands on.
This is a 87 V-6 2.8
IBNFECPO is offline
post #2 of 2 (permalink) Old Jan 20th, 06, 09:29 AM
Re: No dash lights/inter horn on while running
I have a 95 and I had the same problem. I checked all the fuses and every possibly relay I could think of. Turns out, the fuse box was corroded inside right below where the fuse makes contact. I did a quick fix and bypassed the fuse box with an in line fuse, but I'd check the bottom of the fuse box for starters.
JTT5014 is offline
