Engine dying when hard acceleration... - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 17th, 06, 06:41 AM Thread Starter
JL
HI,
i have a 69 camaro RS with a 350 engine.
When I do a hard acceleration from stand position (like at a traffci light),the engine die on me, but if the car is allready running even at slow speed everything is fine. If i accelrate on neutral there is no problem and the engine rev perfetly.
I had a 750 edelbrock which i change for a brand new pretunned 650 edelbrock, butstill have the same problem.
I also update my dual point ignition for a malory ignition but am still runing hte stock coil.
I'm in England and muscle car specialist are not easy to find.
Thanx for your help.
Jimmy
JL is offline
post #2 of 5 (permalink) Old Jan 17th, 06, 08:41 AM
chris
Re: Engine dying when hard acceleration...
what is your idle at rest in gear?
cfauver is offline
post #3 of 5 (permalink) Old Jan 17th, 06, 09:13 AM Thread Starter
JL
idle at 600.
JL is offline
post #4 of 5 (permalink) Old Jan 17th, 06, 10:32 AM
YOU MIGHT WANT TO CHECK YOUR TIMING TO SEE IF ITS ATLEAST WITHIN FACTORT SPECS. IF IT IS TOO RETARDED YOU WILL YOU WILL HAVE A HESISTATION OR AN OFF IDLE BOG.IF IT STILL PERSISTS CHECK YOUR ACCELERATOR PUMP ON CARB. MAKE SURE IT IS SET PROPERLY ALTHOUGH IT IS HIGHLY UNLIKELY 2 CARBS DOING THE SAME THING....WWW.HARDCOREPARTS.CA
pro1 is offline
post #5 of 5 (permalink) Old Jan 17th, 06, 01:17 PM Thread Starter
JL
Is this can't come from the coil??? like nor enought spark???? or not going well with the distributor???
JL is offline
