Small Problem I hope? - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 23rd, 06, 04:29 PM Thread Starter
Unhappy Small Problem I hope?
I just had a newly built 383 stroker v8 small block put in my 1980 camaro and well after driving it a while it started to idle really high now its so loud! and it slows down when you put it into gear but its still quite a bit faster then it should be. It doesnt have that nice slow lub to it like its supposed to and it diesels when you shut it off in park. I was wondering if you thaught this was a minor carborator adjustment or if maybe it was a vaccum problem? Thanks for your input!
camaro_cowgirl is offline
post #2 of 10 (permalink) Old Jan 23rd, 06, 04:55 PM
Re: Small Problem I hope?
Although Idle Will Increase Slightly As The Rings Breakin It Wont Happen Immediately...a Vacuum Leak Is More Than Likely The Culprit Or Also Check To Make Sure Your Carb Isnt Slightly Leakin Down.until You Get It Fixed,and Immediately Shut Engine Off In Gear To Avoid The Deiseling......plain Hard On An Engine
pro1 is offline
post #3 of 10 (permalink) Old Jan 23rd, 06, 05:04 PM
It could be just a sticky choke, too, possibly even from interference with the air cleaner.
The choke is a round can on the passenger side of the carb, with a rod connecting to the butterfly valve on the top of the front 2 barrels ('scuse me if I'm oversimplifying, please, don't know you and want to make sure what I type is understandable!) There is also a rod that connects to a "fast idle cam" to raise the idle when the choke is closed.
Do this: get the motor warmed up fully. Then take off the air cleaner and look at the choke butterfly, it should be completely open.
Blip the throttle (with the aircleaner still off) and see if the idle settles down. If it did, then the bottom of the air cleaner is interfering with the choke linkage.
If it didn't then blip the throttle while pushing the butterfly valve open with your hand. If the idle setlles down, something is wrong with the choke.
Lets us know what you find, and also what kind of carb you have?
post #4 of 10 (permalink) Old Jan 23rd, 06, 06:32 PM
Fine description Jim. I know I tend to overlook the easy stuff sometimes.
dnult is offline
post #5 of 10 (permalink) Old Jan 23rd, 06, 06:56 PM
distributor loose? moved off timing?
sean
You Can't Fake Indifference
69 Camaro Convertible
57 Chevrolet Nomad
Jeeps
buzzworth is offline
post #6 of 10 (permalink) Old Jan 23rd, 06, 08:09 PM
Wes
Agree,..I think your timing as too advanced. You probably need to rotate the distributor clockwise a bit,..should calm her down.
Then get a timing light and set her to 10 degrees and work from there.
Straight-line-69 is offline
post #7 of 10 (permalink) Old Jan 23rd, 06, 10:24 PM
Ray P.
camaro_fever68's Avatar
I may be wrong, but sounds like idle was set cold and right after warm up, it's idling a little high. Pull the air cleaner and use a flat screw driver to turn the idle down till you like it. You can't miss the idle screw. It's on the side the carb, at the bottom. Sets the butterfly opening.
Ray
camaro_fever68 is offline
post #8 of 10 (permalink) Old Jan 28th, 06, 05:22 PM
stevo camaro's Avatar
sean
That's the first thing I thought too. Had it happen once actually.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #9 of 10 (permalink) Old Jan 29th, 06, 12:38 AM
Your idle is way too fast......That is why you have run-on. Let your engine warm up and adjust it to specs. I'm not sure what the specs are for your engine, but it shouldn't be above 800 RPM.
Camaro buds until the end!!!
Camaro Dave is offline
post #10 of 10 (permalink) Old Jan 29th, 06, 05:53 AM
Harry
dawg's Avatar
recheck your settings timing etc.
you did retorque your intake and heads after a few runs didnt you????????
if not you have a huge vacum leak.
434 stroker
US Navy retired
dawg is offline
