2001 Throttle Body - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 26th, 06, 11:16 AM Thread Starter
2001 Throttle Body
At random times when I start my car, it takes 10-12 turns before it turns over. Once it does, I have reduced power, spitting and choking. Eventually I'm able to get it started and it runs just fine. Here's what the dealer has done so far based on inspection and computer analysis:
Replaced the catalytic converter
Flashed the computer (it reported a problem with the throttle body)
Replaced the computer
Replaced the throttle body
Has anyone else experienced this problem? Any ideas on what to do next?
louanndelosua is offline
post #2 of 9 (permalink) Old Jan 26th, 06, 03:13 PM
Re: 2001 Throttle Body
what kind of car and engine ?
jrt69z is offline
post #3 of 9 (permalink) Old Jan 26th, 06, 04:22 PM
It may be a bad fuel pump or fuel pump relay. Engine is cranking for a long time to build up oil pressure and in so doing, closing the parallel power path for the fuel pump.
You should hear a buzz back at the rear of the car for 2 seconds when turning the ignition key to the IGN position. After this event, the fuel pump turns off. Then when START is selected, the relay closes and fuel pump turns back on to pump.
You might troubleshoot power to the fuel pump to make sure the relay is doing its job. Voltage at the pump connector at the tank should be within 1/2 volt of battery voltage. If voltage is low, I'd change the relay after checking the harness for any broken strands, corrosion, and loose connections.
But yes, it would be good to know the make & model. Shoot, I could be out in left field.
Oh, welcome to the Club!! Newbies buy the first round, I'll have a Long Island Iced Tea.
post #4 of 9 (permalink) Old Jan 26th, 06, 05:11 PM
BonzoHansen's Avatar
f/p relay
TC Member #13
BonzoHansen is offline
post #5 of 9 (permalink) Old Jan 27th, 06, 07:11 AM Thread Starter
I have a 2001 Camaro Convertible with a stock V6 engine (it's a GIRL Camaro which is OK because I'm a girl).
post #6 of 9 (permalink) Old Jan 27th, 06, 03:51 PM
when who ever did the work,check the fuel pump pressure?that would be the 1st place to look. i cant rember off hand what the spec is,im going to guess it should be around 50psi.also when was the last time the fuel filter was replaced?icant figure out why they would have replaced the t body.do you have a check engine light on when driving?if they replaced the convertor you should have had a low catalist effecince code and light coming on.sounds like someone was throwing parts at it.let me know.
jrt69z is offline
post #7 of 9 (permalink) Old Jan 29th, 06, 03:31 PM
wdf
correct pressure is 9-13 psi 11 is nominal
wdf is offline
post #8 of 9 (permalink) Old Jan 29th, 06, 07:09 PM
Check it for a plugged up injector also, common problem and it only takes one on a V6 to make it run like crap.
Bill
BowtieBill is offline
post #9 of 9 (permalink) Old Feb 3rd, 06, 06:19 PM
wdf
Bill
only two injectors and both are visable note- throttle body car
wdf is offline
