Wandering Front End - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 29th, 06, 01:07 AM Thread Starter
Wandering Front End
96 Camaro, Alignment Is Good, New Tires, New Brakes And Rotors, Bushings And Rods Tight. It Wanders Mostly Left But Also Right And When I Hit The Brakes It Will Turn The Steering Wheel Mostly Left But Also Right. I Am Thinking It Is A Loose Rack. How Can I Be Sure Or Do You Have Any Other Thoughts. Please Help. Thx
ROBERT GENTUSO is offline
post #2 of 3 (permalink) Old Jan 29th, 06, 05:51 AM
Harry
dawg's Avatar
Re: Wandering Front End
alignment cant be right if its doing that?
take it to a GOOD front end shop and tell em the symptoms.
Ill bet its an alignment problem or a loose worn out front end component.
434 stroker
US Navy retired
dawg is offline
post #3 of 3 (permalink) Old Jan 29th, 06, 07:24 AM
Andrew
Andrew69's Avatar
Check your tire pressure. If your left tire is low, it can pull you in that direction.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
