HELP PLEASE!!! My 95 Camaro won't start!! - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 1st, 06, 04:54 PM Thread Starter
Unhappy HELP PLEASE!!! My 95 Camaro won't start!!
I went this morning to start my camaro and everything was fine until I turned it off. I went to start it again and nothing!!! I tried to start it again and nothing!!! I noticed my Security light was blinking on and off which it has never done before. I waited several minutes and tried it again and the same thing. Nothing. So before i went to work, I disconnected the battery and when I got home I reconnected the battery and tried it again and again...nothing. I know that it must be the PASS II Security System that is malfunctioning and I am just wondering if there is anyone out there who has had a similiar problem and managed to fix it. I would like to know how you fixed it. Thank You.
Rokbrigade is offline
post #2 of 8 (permalink) Old Feb 1st, 06, 04:58 PM
Re: HELP PLEASE!!! My 95 Camaro won't start!!
Dunno Bout That Problem But I Have A 94 And Its Nothing But A Problem , Misfires Bad After Warmed Up
bud419 is offline
post #3 of 8 (permalink) Old Feb 1st, 06, 05:04 PM Thread Starter
I had a similiar problem and I found out that it was a bad fuel pump. I went to Superior Automotive in Anahiem, CA. and they put it in for me for $400.00. They said that all I needed was to buy the part and they'll put it in. I went to Kragen and bought the fuel pump for $180.00 and they installed it for me. Problem solved. The dealer wanted $1600.00 dollars. I said screw that.
post #4 of 8 (permalink) Old Feb 1st, 06, 06:10 PM
take the key to your local chevy dealer and go to the parts area.ask them to test the key with there tester for that.
jrt69z is offline
post #5 of 8 (permalink) Old Feb 3rd, 06, 06:04 PM
wdf
the key is a passive resistor,the most you should have to do is clean the contact area on both sides with a pencil eraser! BUT the most common failure is the key reading contacts in the ignition lock cylinder. repair requires replace lock cylinder with associated wiring harness to base of column/ OR install fixed resistor (same value) in place of harness! not a rookie job
wdf is offline
post #6 of 8 (permalink) Old Feb 3rd, 06, 06:08 PM
wdf
blinking lite means security system problem!
wdf is offline
post #7 of 8 (permalink) Old Feb 5th, 06, 10:42 AM
Do you have a back up key that you could try? That would eliminate the possibility of a bad chip.
Camaro buds until the end!!!
Camaro Dave is offline
post #8 of 8 (permalink) Old Feb 5th, 06, 05:38 PM
Cool Re: HELP PLEASE!!! My 95 Camaro won't start!!
take your car to a place that does autostart alarms they have to do the same thing to install an autostart in all the newr cars. i used to work for one we did it all the time. a lot cheaper that going to the dealer a new key from the dealer is 55 dollars and if it is the key cylinder another 125. alarm place is about 25 to 40 and you won't have to have a special key every time you loose one good luck
ml6-71 is offline
