oh that smell - Team Camaro Tech
post #1 of 12 (permalink) Old Feb 1st, 06, 06:45 PM Thread Starter
oh that smell
i have a cowl hood on my car and aftermarket air cleaner i get alot of fume smells inside the car ..i think its from the cowl hood anyway to stop this from happing? anyway to block the cowl opening?
69 Camaro RS 396bbc
namz111 is offline
post #2 of 12 (permalink) Old Feb 1st, 06, 07:31 PM
chris
Re: oh that smell
you could probably replace the cowl panel seals under the wiper area, they are the triangle seals on each side that keep debris and water out of the lower cowl, its probably blowing down through your vents, also check your firewall insulation or any missing gromets in the firewall.
cfauver is offline
post #3 of 12 (permalink) Old Feb 1st, 06, 07:35 PM Thread Starter
Re: oh that smell
thats all been done still smells...i think what is happening is the fumes are going into the cowl vents from the cowl
69 Camaro RS 396bbc
namz111 is offline
post #4 of 12 (permalink) Old Feb 1st, 06, 08:12 PM
Re: oh that smell
At least in theory, the air goes in the cowl hood, not out... and except at full throttle, the flaqpper door is closed and sealed tight. Then on the other hand, old cars do have their oders... check a post of mine "my smelly car" it was live this week.
post #5 of 12 (permalink) Old Feb 1st, 06, 08:58 PM
Re: oh that smell
From the description, it sounds like no flapper is installed. As Jim said, the way GM engineered the system, the flapper only opened up at times when it would be drawing in air.
If you just like the look of the hood, you could certainly try cutting a foam plug to fill the hole. Fabbing a cold air box that seals to the hood might help too. Check exhaust for leaks in the underhood area.
Eric
Eric Kammerer is offline
post #6 of 12 (permalink) Old Feb 2nd, 06, 12:50 PM Thread Starter
Re: oh that smell
well i bet thats the problem! I dont have a flapper!! Now i am going to getone...
69 Camaro RS 396bbc
namz111 is offline
post #7 of 12 (permalink) Old Feb 4th, 06, 06:40 AM
Re: oh that smell
Hi,
I just went through the same problem with my 69.
First thing, close your side panel vents. If this stops the problem then the cause is under the hood.
2nd thing, Make sure your gas cap is working properly and is on tight.
I had a bad cap and I had all kinds of fumes in my car until I changed the cap.
Good luck,
Schoon
Schoon
SCHOON is offline
post #8 of 12 (permalink) Old Feb 9th, 06, 02:16 PM
Re: oh that smell
I second checking the gas cap. You wouldnt think it would smell that much coming from behind you, but it does.
rlovell383 is offline
post #9 of 12 (permalink) Old Feb 9th, 06, 02:41 PM
Harry
dawg's Avatar
Re: oh that smell
i have a cowl hood with no flapper door and i smell nothing,
but my motor is clean and i have no leaks .
check for leaks etc.
434 stroker
US Navy retired
dawg is offline
post #10 of 12 (permalink) Old Feb 9th, 06, 08:22 PM Thread Starter
Re: oh that smell
Motor is very clean ..trust me you can eat off this one and no leaks
69 Camaro RS 396bbc
namz111 is offline
post #11 of 12 (permalink) Old Feb 9th, 06, 10:23 PM
Re: oh that smell
Have you checked for an exhaust leak coming from underneath the car? Maybe the exhaust gasket(or doughnut) between the header to intermediate pipe could be leaking. Drive with your windows down, until you figure out where the fumes are coming from. Carbon monoxide kills!!!
Camaro buds until the end!!!
Camaro Dave is offline
post #12 of 12 (permalink) Old Feb 10th, 06, 05:31 AM
Re: oh that smell
I"m with dawg. I have no flapper door and smell nothing. Check elsewhere.
yelo69 is offline
