1994 Z28 is stalling out - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 4th, 06, 12:49 AM Thread Starter
Need some help with my Z; it stalls outs after about 5-10 minuate when in idle. I have changed out fuel filter, and pump with no change.
I'm in the military and overseas and do not have all the computers to check out the vehicle. The mechanic I'm working with thinks it might be a distributor problem but I hate to tear into the car with definite diagnosis. If anyone has had this type of problem or know of a fix please let me know.
wongja's z28 is offline
post #2 of 6 (permalink) Old Feb 4th, 06, 02:44 PM Thread Starter
Re: 1994 Z28 is stalling out
[QUOTE=wongja's z28]Need some help with my Z; it stalls outs after about 5-10 minuate when in idle. I have changed out fuel filter, and pump with no change.
I'm in the military and overseas and do not have all the computers to check out the vehicle. The mechanic I'm working with thinks it might be a distributor problem but I hate to tear into the car without definite diagnosis. If anyone has had this type of problem or know of a fix please let me know.
post #3 of 6 (permalink) Old Feb 5th, 06, 08:09 AM
how many miles on the car? Have you had the opti ever replaced? how does the car start, right away or does it turn over for a while befor starting? Is it running smooth befor it dies? Need more info
T'S 95T/A is offline
post #4 of 6 (permalink) Old Feb 8th, 06, 04:48 AM Thread Starter
T's 95T/A thanks for replying; to answer your questions, the car has little over 72K and I don't believe the opti has been replaced (bought the car about a year ago), the car takes couple turns before it started (reason I replaced the fuel pump). The problem happens when the car is idling and runs smooth for about 5-10 minutes and sputters out like its not getting any fuel. I'm planning to replace the opti when it comes in. Am I on the right track? If after replacing the opti the problem continues what's the next course of action?
post #5 of 6 (permalink) Old Feb 8th, 06, 09:55 AM
I was leaning twards opti or it may also be your O2 sensors when the car is idleing can you rev the car? how does it sound when you rev it while its running? Opti's tent to break up at higher rpm's. if it revs fine I would start looking at sensors like MAF and O2's. I'll look through some posts on LT1TECH.com and see if I can come up with any other suggestions. or you may want to post this problem on LT1TECH.com very good site for LT1's what branch are you in? I was in the air force myself. Good luck and
THANK YOU FOR SERVING OUR COUNTRY
post #6 of 6 (permalink) Old Feb 10th, 06, 11:07 AM
it could also be your ignition module heating up and shutting off. another problem with 4 gens.
