'94 Z28 acting like a Ford - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 4th, 06, 12:02 PM Thread Starter
Exclamation '94 Z28 acting like a Ford
I was wondering if anybody knew what might be going on with my car. I have a '94 Z28, and it died on me last night. It was running fine, until I accelerated from an intersection. It died about halfway through. I pulled over, and tried restarting. I got a little dieseling and about 100-300 rpms for a second, then nothing. The car won't even turn over now. The starter works, and all fluids are new in the car. Can anybody help?
txgi213 is offline
post #2 of 7 (permalink) Old Feb 4th, 06, 04:04 PM
Re: '94 Z28 acting like a Ford
this responce may sound stupid but have you checked the fuse for the fuelpump it sounds like a fuel problem. did it die hard or kind of choke up?
miami79 is offline
post #3 of 7 (permalink) Old Feb 4th, 06, 07:47 PM Thread Starter
Lightbulb Re: '94 Z28 acting like a Ford
It died softly, with a little sputtering. I checked all the fuses and relays today. They were fine. I also ran carb cleaner through a vacuum line to rule out fuel problems. I am starting to think coil or distributor.
txgi213 is offline
post #4 of 7 (permalink) Old Feb 5th, 06, 08:56 AM
well your car does not have a "distributor" per say. It has a optispark it is mounted in the front of the engine just below the water pump. Very common for this to fail any where form 75k miles and up. expensive job for a shop to do $800- $1000. get your codes checked on the car. got to shbox.com or LT1TECH.com for more info if you attempt to do this yourself
T'S 95T/A is offline
post #5 of 7 (permalink) Old Feb 6th, 06, 10:39 AM Thread Starter
It seems to be the optispark. The water pump is leaking coolant onto the unit. I had this water pump replaced less than a year ago. Kinda pisses me off. The optispark was replaced 2 years ago as well.
txgi213 is offline
post #6 of 7 (permalink) Old Feb 7th, 06, 08:42 AM
if I were you and was going to keep the car for awhile, I would upgrade to a 95+ and up optispark because it is vented. It will keep the moisture out of it from the road or your waterpump. My guess is that if this was done the first time you replaced it you would not be replacing it again. good luck are you gonig to do this work yourself?
post #7 of 7 (permalink) Old Jul 24th, 06, 07:04 AM
the 94 optispark has a splined hole for a splined shaft. the 95 and up have a shaft already made on to the optispark. how do you convert??also how do you check an optispark to see if its going bad (some times). mine will crank up right now and run fine, but after driving about 10-15 miles it startes running real rough , deiseling and then goes dead. wont start. it will turn over but wont start. then after a wait of any where from 5 min to 2 hours it will start right up and run great for another 10-15 miles...
prostreet is offline
