Need Help w/"80" Camaro Shifter Problem!!! - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 5th, 06, 07:47 AM Thread Starter
Angry Need Help w/"80" Camaro Shifter Problem!!!
I have a 1980 Camaro with the factory auto shifter. My problem is the shifter keeps jamming. I've tried 3 times to fix this problem and used GM shift cables each time. The new cable will work for a week or mabey two and then jam , preventing the shifter from being moved out of park , until the cable is disconnected. The last time I tried to correct this problem , I took the car to AAMCO , figureing it might be tranney induced. NO DICE. One week later I'm in the driveway....It seems the part of the cable that slides out , when moveing the shifter , bends , preventing it from slideing back in , resulting in Park Only. Anyone w/insight to this problem and how to correct it ?? Thanks Robert
Robert05 is offline
post #2 of 3 (permalink) Old Feb 5th, 06, 03:15 PM
wdf
Re: Need Help w/"80" Camaro Shifter Problem!!!
disconnect cable and move shift lever on side of trans by hand. you should feel
all detents about the same- with park being slightly harder. if ok check angularity betwen cable holding bracket and trans shift lever, this must be a
STRAIGHT push/ pull alignment!
wdf is offline
post #3 of 3 (permalink) Old Feb 6th, 06, 10:54 AM Thread Starter
Thanks for the info!! Now mabey I can put my shifter back together. Thanks again Robert
Robert05 is offline
