94 Camaro Will Not Start - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 10th, 06, 03:45 PM Thread Starter
I have a 94 Camaro Z28 5.7L V8. Currently it has been sitting for maybe 5 months during the winter. It is in a garage.
I start it every 2-3 weeks to let it run for a bit. Last time i went to start it the battery was dead, so I took the battery out, put it on the charger, it didn't say it was taking a charge, but anyway put it back in the car and it started it fine.
I put the same battery in my other car and it started it fine as well so the battery should not be an issue here but it may be the cause for the problem I am now having. I had to take the battery in and out of the Camaro quite a few times, but eventually once it started working again it was fine.
I took the battery out over night and put it back in just to make sure it still started fine, but when I put the key in, turn it, the power comes on, all the lights are on and everything, but when I turn to start the engine i just here 1 click and thats all. I turn it many times and I only get 1 click each time I turn the key.
Again I tried the batter in the other car and it works fine, I put my other car's battery in the camaro and got the same problem of the 1 click when I try to start the car, but again it has all power, lights are on and everything.
I replaced the starter 1 week before putting the Camaro away for the winter so the starter isn't old or anything. Things are pointing to maybe the anti theft system (which I BELIEVE is called VAT, but I'm not positive).
Any suggetions? I called GM and they said to tilt the wheel down all the way and then try starting it again, that didn't work. Someone told me to pump the brakes 5 times within 3 seconds or so, that didn't work. My brother found a fuze he said was worn out and replaced it but that still didn't fix it.
Chase is offline
post #2 of 9 (permalink) Old Feb 10th, 06, 09:14 PM
wdf
Re: 94 Camaro Will Not Start
measure voltage at the heavy starter terminal to battery ground while someone tries to start the car / this will check the battery and the connections to the starter let us know what you read
wdf is offline
post #3 of 9 (permalink) Old Feb 10th, 06, 10:15 PM
What size motor is your other car? Is it smaller than a 5.7? The battery might have just enough charge to start the other car, but might not have the charge for the Camaro. Try a new battery with at least 700 to 800 CCA'S (Cold Cranking Amps). It could be your old battery isn't holding enough charge.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 9 (permalink) Old Feb 11th, 06, 08:34 PM Thread Starter
It is the 5.7L engine. The battery seems to be fine, i take it out and put it in the cavalier (4 cyl) and it starts it fine. It is an 800 battery. I also take out my cavalier battery (also 800) and put it in the camaro and get the same problem. so i come back to the idea it must be the starter or the security system may have shut everything down. possibly something wrong with the key but nothing happened to the key that would have maybe screwed up the chip in it. no magnets or anything.. anything else?
Chase is offline
post #5 of 9 (permalink) Old Feb 11th, 06, 09:40 PM
BonzoHansen's Avatar
Chase, maybe do us a favor and not post the same question in multiple threads?
TC Member #13
BonzoHansen is offline
post #6 of 9 (permalink) Old Feb 13th, 06, 05:08 PM
Unhappy Re: 94 Camaro Will Not Start
Originally Posted by Chase
It is the 5.7L engine. The battery seems to be fine, i take it out and put it in the cavalier (4 cyl) and it starts it fine. ...
Well you've ruled out the battery, but there's a heck of a lot more to check. I'm surprised your very next post didn't give an follow-up to mr wdf's post.
dnult is offline
post #7 of 9 (permalink) Old Feb 16th, 06, 03:38 PM Thread Starter
i'm just waiting for my brother to be around he is taking mechanics in college so he knows how to do these things, i don't. i will post again in here when he looks over the suggestions and tries some stuff. thanks.
Chase is offline
post #8 of 9 (permalink) Old Feb 21st, 06, 10:35 AM Thread Starter
hey guys my brother took the starter out and said it was scrweed so we got a new one and just waiting for him to change it when he has time. that is probably what the problem is just incase anyone wanted to know.
Chase is offline
post #9 of 9 (permalink) Old Feb 22nd, 06, 09:04 PM
Didn't you say that you replaced the starter before you put the car up for the winter? If it was new, it should not go bad just sitting there for a few months. Maybe you have another problem rather than the starter. Let us know what happens.
