starter bolt broke off in block... - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 11th, 06, 02:51 PM Thread Starter
The bolt that goes into the block for the starter head broke off.Went and got an easy out to get out the rest after drilling out the majority of the bolt. Well the easy out is now stuck in there.How can I get it out. Will using a torch to put heat on it for 20 seconds damage the block? Thanks
Luke805 is offline
post #2 of 5 (permalink) Old Feb 11th, 06, 03:13 PM
Bill
Re: starter bolt broke off in block...
Luke,
Is the easy out broken or just stuck ? If its broken you are probably out of luck, there is no drill that I know of that will drill them, they have to be edm "blasted" out. If it is just stuck, you should be able to turn it clockwise and it should loosen right up. I doubt that the torch will help anything. You might be able drill from the top and then knock out the e-z out ? I have also heard of guys using a dremel tool and one of thier small diamond bits to grind away the e-z out, but it will probably require several bits and a LOT of patience.
Whatever you do, stop before you ruin it to the point that it cannot be repaired by your machine shop.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 5 (permalink) Old Feb 14th, 06, 11:37 AM
A little heat works wonders, so if you use a small tip on the torch, and just heat around the outside area of bolt hole, up along sides of hole, you might be able to get it out.
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 5 (permalink) Old Feb 14th, 06, 03:38 PM
Rob.
Put a nut over the hole and mig weld the inside of the nut to the top of the bolt, I have used up to a half a dozen nuts, but it never fails.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
1969ss is offline
post #5 of 5 (permalink) Old Feb 19th, 06, 01:00 AM
Rob
In Plain view Genius.
MichiganMan is offline
