1994 3.4L Camaro Cranks but won't start. - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 15th, 06, 07:34 PM Thread Starter
Hi, I have a 94 camaro that was running fine then started to run real rough so i changed the egr valve and it ran for about 3 min and ever since then it hasn't run. I thought it could be the fuel pump so i put a new one in. It has spark. I don't know whats wrong. It cranks over fine. Every once in awhile it will catch and run for lake a second maybe. What do you guys think? Ive sprayed starting fluid in the throttle body while cranking it and that doesnt help either. There are no codes being given off. When I crank it over I can smell the gas. I don't know.Thanks.
Links_56 is offline
post #2 of 2 (permalink) Old Feb 17th, 06, 10:13 PM
Re: 1994 3.4L Camaro Cranks but won't start.
Pull out your spark plugs and check the condition of them. Are they fouling out? What condition are they in? Clean the plugs and check the gap. See if that helps.
Camaro buds until the end!!!
Camaro Dave is offline
