something went wrong while i was driving home today...i think its bad - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 24th, 06, 01:33 PM Thread Starter
Bryan Hall
i am not sure what happend but i know it cant be good..i was going to home home from school today from college to my home which is 3 hrs away before i left i checked all my fluids and everything was good.car has been runing great. so i stated out and only got 15 miles before i smelled oil...this usually happen b/c i have a small leak by my header and it drips liek one drop nd burns off but this leak kept going and smelled bad..then the smoke came..alot of it. and smoke also came out my exhaust. i got scared and pulled over ..checked the oil and it was only halfway on the dip stick and the leak was a little worse i am not sure where the oil went but the smoking out of the exhaust has never been there. so i got some more oil..topped it off and turned back around ...my plugs fouled and it started to run bad and contiue smoking....what could this be from..the engine is fairly new ..brand new heads cam intake carb lifters....i hope a ring didnt go....any ideas
My car pics...
dallas car show pics plus some of the cars i am building at work
importkiller69ss is offline
post #2 of 4 (permalink) Old Feb 24th, 06, 01:40 PM
Re: something went wrong while i was driving home today...i think its bad
pull your plugs, and see what there is to see. If you can finds a compression guage, check the compression, heck, if you can't find one go buy one.
What was your temp guage doing during all this? Is the radiator still full?
post #3 of 4 (permalink) Old Feb 24th, 06, 01:47 PM Thread Starter
Bryan Hall
temp was normal about 180 oil pressure was the same never moved...just came out of no where
My car pics...
post #4 of 4 (permalink) Old Feb 24th, 06, 04:42 PM
Russ
How many miles were on the bottom end when you put the new heads on? What happend to me some time ago , I installed a new set of heads on a bottom end that had a quite a bit of miles on it and after about a hundred miles the rings failed. Don't know exactly what causes this but heard of this happening a few times to other people as well. Another place to look is the pcv hose you may be sucking oil through there , this also happended to me on a fresh rebuild.it looked like a mosquito sprayer I was freaked out at first thinking the worst had happended but tracked it to the pcv hose. That was an easy fix though I put a baffeled pcv grommet into the valve cover.Problem solved. Man do I have issues!! Anyway hope this helps it took an hour to type lol.
19694speed is offline
