slight grinding noise - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 25th, 06, 03:45 AM Thread Starter
matt
Send a message via AIM to buckie1269
I have a 92 RS camaro that while driving striaght you can slightly hear and feel a grinding noise from the front. however when steering to the right all is normal. what is this?
buckie1269 is offline
post #2 of 3 (permalink) Old Feb 25th, 06, 07:25 AM
stevo camaro's Avatar
Re: slight grinding noise
Could be a wheel bearing, could be a loose brake caliper. I'd pull the wheels and look ASAP.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #3 of 3 (permalink) Old Feb 25th, 06, 08:53 PM
Does the grinding noise change when you step on the brakes? Like Steve said... Pull the wheels and look. Your brake pads might be grinding into your rotors.
Camaro buds until the end!!!
Camaro Dave is offline
