84 camaro - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 26th, 06, 05:55 AM Thread Starter
Question 84 camaro
84 camaro wont start brand new battery, altenator charges fine, engine clicks, thought it may be the starter but i was told by someone that its the ignition, how is this fixed?
fripples98 is offline
post #2 of 4 (permalink) Old Feb 26th, 06, 09:55 AM
Re: 84 camaro
If the starter clicks when you try to start it, make sure all of the electrical connections on the battery and starter are clean and tight. If that doesn't solve the problem it's probably time for a new solenoid and/or starter.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Feb 26th, 06, 03:44 PM Thread Starter
Re: 84 camaro
tyvm for the help.since the key stays back when i try to start it should i fix the ignition then look at th starter/solenoid or does it matter?
post #4 of 4 (permalink) Old Feb 28th, 06, 12:59 PM
Re: 84 camaro
If the key stays in the start position when you let go of it I'd fix that first. It could cause a meltdown if for some reason you couldn't get it out of the start position.
12run is offline
