69 camaro steeringwheel - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 1st, 06, 08:35 PM Thread Starter
Hello everyone, this is my first post. I just want to say, I really enjoy all the information here, alot of good information posted. Now my question. Is there any another way to pull the steeringwheel off to replace, other than buying the puller? Thanks.
pa69cam is offline
post #2 of 7 (permalink) Old Mar 2nd, 06, 06:05 AM
Re: 69 camaro steeringwheel
Borrow a puller if you have to. You stand a good chance of damaging the upper column bearings if you beat on the steering wheel and/or hub to get if off. It is really a tight secure connection.
BTW, make sure that you have the puller square to the steering column shaft and hub when you start to pull it off. Otherwise, you can break the bolt(s) that you threaded into the hub. (Don't ask me how I know!)
JIML82
JIML82 is offline
post #3 of 7 (permalink) Old Mar 2nd, 06, 06:31 AM
Christropher
You can rent a puller for free from your local Autozone with a cheap deposit, like 15 bucks.
Christropher
...in pieces still.
clwilcox33 is offline
post #4 of 7 (permalink) Old Mar 2nd, 06, 12:32 PM
Steps
DONT WHACK to free..Im in the proscess of fixing ours because of someone doing so to mine
https://www.camaros.net/forums/showth...t+steering+box.
Get a puller
If cant. put a longis bolt in each of the puller holes
between these a peice of plate that has holes that the bolts go thru. between the plate and steering shaft put another bolt and nut, the head of the bolt on the shaft and the nut at the end of the bolt thread under the plate.
Carfully unwind the nut holding the bolt head with a ring spanner. this will lift the steering wheel enough to pop it free. Its best to have a helper to hold things straight
Steptoe is offline
post #5 of 7 (permalink) Old Mar 2nd, 06, 02:39 PM
Harry
dawg's Avatar
or you can buy bubba a six pack to yank it off!
434 stroker
US Navy retired
dawg is offline
post #6 of 7 (permalink) Old Mar 2nd, 06, 05:13 PM Thread Starter
Thanks guys, I'm gonna try to use a puller. I already had bubba try and yank it off. It's still in place.lol
69 Plain Jane, Pennsylvania.
pa69cam is offline
post #7 of 7 (permalink) Old Mar 2nd, 06, 07:42 PM
Bubba is a bad idea.......use the puller!
Camaro buds until the end!!!
Camaro Dave is offline
