High RPM Miss - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 6th, 06, 06:24 PM Thread Starter
Exclamation High RPM Miss
I have a 68 Camaro with 327, I have recently put an Edelbrock Performer Intake (2101) and Carb (1406). Also I put a HEI distributor before I did the intake and carb swap. My issue is that when the engine is cold and at WOT the engine hesitates at 3500-4000 RPM's. After I drive around for 15-20 minutes it doesn't do this any longer and runs strong. I am running at 10 degrees BTDC at idle and have not checked my mechanical advance but I believe it to be good. I thought it was an issue with the choke and have removed it completely and this does not help things. The carb from the factory is setup for economy, maybe its too lean cold and at high RPM? Maybe I need to change the push up spring?
sweeks68Camaro is offline
post #2 of 7 (permalink) Old Mar 7th, 06, 01:20 PM
Re: High RPM Miss
First of all I wouldn't advise WOT on a cold engine. Quadrajets came with a lockout tang on the secondaries that wouldn't allow the secondaries to open when the choke was closed. They did this for a reason. If the choke is working properly the engine will start to load up after you exceed a certain rpm because it cannot draw enough air past the choke. Reset the choke so it idles and runs properly when cold and stay out of the secondaries until it warms up.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 7 (permalink) Old Mar 7th, 06, 03:38 PM Thread Starter
Re: High RPM Miss
Thanks for the input. As mentioned I am running an Edelbrock Performer Carb with NO choke.
post #4 of 7 (permalink) Old Mar 8th, 06, 01:45 PM
Re: High RPM Miss
If you're planning on driving the car in cold weather I would put the choke back on. I removed the choke on my Holley, but I never drive the car when it's below 50*F and I take it easy until it warms up.
12run is offline
post #5 of 7 (permalink) Old Apr 1st, 06, 09:32 PM
Re: High RPM Miss
I think I might have a possible answer to your problem. When you drop an HEI into a non HEI application there are two other wiring changes you need to make. #1 Put 12v straight into the HEI. Usually from the fuse block.... #2 Don't Use The Resister Wire.... You should have a white/tan/orange wire coming from the starter to the coil... You don't use the old coil anymore... Just tape the resister wire out of the way.... I have a 70 camaro with the same problem (Does not like to idle when cold) Being from Central florida I never had much call for a choke anyway. (I thought it was just cold natured) although I never had problems with it breaking up at high RPM's. I was at the track one night and some friends where helping me do some on the spot tuning and they asked if I had Made the above mentioned changes. They told me that on cars with points type distributers only used 12v to start and then dropped to 9v to keep the points from excessive wear. I must tell you that I have not made these changes yet and you will need to double check these instructions with someone with better knowledge on the subject. Hope this helps....
Hotrod 70 BB is offline
post #6 of 7 (permalink) Old Apr 4th, 06, 08:49 AM Thread Starter
Re: High RPM Miss
Thanks for the input. I should have mentioned, I did swap out the resistance wire. I'm thinking the issue is more carb related. Maybe too rich. I'm waiting on smaller jets and as soon as I get them I will swap them out and see what happends.
post #7 of 7 (permalink) Old Mar 19th, 08, 01:36 PM Thread Starter
Re: High RPM Miss
Turned out, bad lobe on cam. Problem solved.
