Vats 92 V-6 Camaro - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 7th, 06, 01:26 PM Thread Starter
Vats 92 V-6 Camaro
I am a new member here and I could use some help. I just purchased a 92 v-6 camaro and the previous owner lost the keys. Before I knew about vats, I thought a new ignition cylinder would work. I have heard the code(resistance) could be obtained from the key, and that a security bypass could be bought. My question is, how would I find the vats code on the car without the key, so I could have a key made? Hope this makes sense, I am not real up to date on the new electronic stuff. Thanks...Phil
nitevermin is offline
post #2 of 6 (permalink) Old Mar 7th, 06, 02:05 PM
Kevin
SixtyAte's Avatar
Re: Vats 92 V-6 Camaro
Contact a local locksmith and see if they can interogate the Vats system to find out what frequency you module is using. One found they can cut you a new key with the proper code. The VATS bypass system is used for remote start systems and the proper code must be used. A locksmith should be alot cheaper than towing it to a GM dealership.
Kevin
SixtyAte is offline
post #3 of 6 (permalink) Old Mar 7th, 06, 02:41 PM
https://www.camaros.net/forums/showth...highlight=VATS
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 6 (permalink) Old Mar 7th, 06, 04:39 PM Thread Starter
Thanks for the help Mark. I will try your advice as soon as I can and will let you know the outcome. Once again, Thanks...Phil
post #5 of 6 (permalink) Old Mar 21st, 06, 09:19 AM
Send a message via AIM to milehigh67
The VATs system is pretty easy to fool. The pellet in the key is simply a resistor. If memory serves there are 14 different resistances. You can purchase these keys from mid america (which is typically a vette site). Or you can actually buy a VATS bypass switch from the same site.
www.madvet.com
good luck
1967 Convertible SS 350
milehigh67 is offline
post #6 of 6 (permalink) Old Mar 21st, 06, 04:45 PM
I've soldered in resistors I've purchased from RadioShack. Cheap and easy.
whitesoxfbody is offline
