Gas line problems - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 7th, 06, 10:13 PM Thread Starter
Gas line problems
I have a 79 camaro. I noticed there is a gas leak coming from the rear. when i get under the car I notice that there is a rubber line coming from the top of the gas tank that runs into a metal line. It looks like the rubber is all rotten. Is this an easy line to fix without dropping the gas tank? does the rubber line connect to a metal line on the gas tank? any ideas will help, thanks guys.
iroc5570 is offline
post #2 of 4 (permalink) Old Mar 8th, 06, 12:37 AM
Harry
dawg's Avatar
Re: Gas line problems
yes its an easy fix but youll have to drain some fuel .
434 stroker
US Navy retired
dawg is offline
post #3 of 4 (permalink) Old Mar 8th, 06, 01:19 PM
Ron
Yes there is metal on each end. Will need to drop tank just enough to unhook line and install new one. Its nice if tank is near empty.
69-x55 is offline
post #4 of 4 (permalink) Old Mar 8th, 06, 07:20 PM Thread Starter
how do you mean i need to drain some fuel? should i get like an oil pan and put it under the car and unhook the line at the bottom of it before it hits metal, and just let whatever drain out that will drain out? or is there more of a process to it than that??
iroc5570 is offline
