92 Camaro Starting Problems - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 10th, 06, 02:57 PM Thread Starter
I Have A 92 Rs 305 Camaro, That I Just Cant Seem To Get Running. First I Thought It Was The Starter, It Wasnt, When I Put The Starter Back In Place, All The Lights Never Came Back On, Maybe I Installed The Starter Wrong , I Even Bought A New Battery, Same Thing, What Do Youn Think
SCANLAN1 is offline
post #2 of 5 (permalink) Old Mar 10th, 06, 02:59 PM Thread Starter
Re: 92 Camaro Starting Problems
Have Any Ideas About My Problem
SCANLAN1 is offline
post #3 of 5 (permalink) Old Mar 10th, 06, 03:59 PM
Does it crank over at all? clicking noise, completely dead? Start with the simple double checks. make sure the battery power feed both to the starter and the pigtail connection are good.
Double check the connections, to the battery and the starter. and make sure they a clean. Make sure the car is in park before trying to start.
make sure the wires to the starter solenoid are on and proper.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #4 of 5 (permalink) Old Mar 11th, 06, 02:05 PM
Smile Re: 92 Camaro Starting Problems
Check your connections again. Try taking the power and ground wires off of the starter and reinstall, making sure to place power and ground at there correct places. Also check you're ground area for the battery. Make sure its free of corrosion and has a snug connection. Check the ground at the starter area also. Make sure to hook all of the power wires up at the starter. there is probably more then one. (leading to accessories and so forth.
FirstKnight is offline
post #5 of 5 (permalink) Old Mar 11th, 06, 07:14 PM
If you don't have power at all and the battery is good, check your main power feed line that connects to the positive battery cable for a bad connection. Chances are that while you were working on the starter, the wire came loose.
Camaro buds until the end!!!
Camaro Dave is offline
