RS trouble shooting help - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 17th, 06, 08:09 AM Thread Starter
I was trying to trouble shoot my RS flip lights last night. I disconnected one of the vacuum lines and sucked on the line to check for leaks. I could hear air leaking in from the bottom area of the Relay Vacuum Switch that is mounted on top of the vacuum tank.
This may be a very dumb question but is the Relay supposed to leak?
I also double checked the manual switch on the relay to see if moving it one way or the other would change things and it did not fix the leak.
Could the relay be stuck on manual open mode to vent the air so I can manually open and close the covers?
jrager is offline
post #2 of 8 (permalink) Old Mar 17th, 06, 08:38 AM
click's Avatar
Re: RS trouble shooting help
the switch can get gummed up over the years with exhaust gases if the filter in the line from the manifold isnt good. Get a Vac tester guage/pump that also 'gives' vacuum, its one of the neatest tools I bought, then you can apply vac to all the parts seperatly to find leaks. There are so many connections on those vac hoses that can leak or the hoses split or the 't' breaks etc.
click is offline
post #3 of 8 (permalink) Old Mar 17th, 06, 09:15 AM Thread Starter
I have access to a vacuum tester but it could be a few days before I get ahold of it.
All of my vacuum lines, fittings, and check valves are new. There is one old section of line that I am replacing tonight but there is no leek anywhere except for the relay.
I am guessing by your responce that the relay should not be leeking air. The relay is new but that does not mean it is functioning correctly.
I will spend some more time on it over the weekend.
jrager is offline
post #4 of 8 (permalink) Old Mar 17th, 06, 09:25 AM Thread Starter
I found my answer on another post.
https://www.camaros.net/forums/showthread.php?t=71320
The relay should not leek. It also seems that a leek from the bottom of the relay is common.
jrager is offline
post #5 of 8 (permalink) Old Mar 17th, 06, 09:27 AM
The relay only leaks air when the actuators are moving, or if you have a leak past the actuator pistons. The relay directs vacuum to one side of the actuator piston or the other, and then vents the other side of the actuator. If it didn't do that the actuator would lock in one position. So if you hear air leaking past the relay and your actuators are in the position they are supposed to be in (closed with lights off, or open with lights on) then one (or both) of you actuators are leaking internally.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 8 (permalink) Old Mar 17th, 06, 09:33 AM Thread Starter
Thanks Mark.
My lights were off with the light doors closed and the engine was off when I noticed the leak in the relay.
I will vacuum test the acuators as well.
jrager is offline
post #7 of 8 (permalink) Old Mar 17th, 06, 09:41 AM
Chris
Where did you buy your relay? I have heard bad things about the repro relays(leaking). I saw where Rick's sells two different ones, a repro that looks like original, and one they call a workable GM replacement.
I called them a while back and the guy I spoke with told me he would recommend buying the GM one. Even though it doesn't look like original he said they work alot better. I still haven't bought one yet as I'm not to that point yet. Let us know what you find out.
ck 2 is offline
post #8 of 8 (permalink) Old Mar 17th, 06, 09:49 AM Thread Starter
Unfortunately the previous owner replaced this part before I bought the car so I donít know where it came from.
I checked Rick's catalog and it is the relay pictured to the left. The all black plastic looking one not the one with the metal top.
I am guessing this is the reproduction and not the more expensive GM replacement. I say this because the guy who had the car before me put allot of cheap effort and parts into the car.
I may wait until Spring Carlisle to pick up a new one. I will keep this information in mind.
jrager is offline
