how can you tell when the trottle body or torque converter switch goes out? - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 20th, 06, 07:06 AM Thread Starter
Question how can you tell when the trottle body or torque converter switch goes out?
i have a 89 camaro and at sudden stops such as red lights or stop signs it cuts off. but starts back up. i check everything and have came up with nothing also it doesn't have any codes.
goldyiroc is offline
post #2 of 3 (permalink) Old Mar 20th, 06, 06:08 PM
Re: how can you tell when the trottle body or torque converter switch goes out?
what size cam do u have
richardls1 is offline
post #3 of 3 (permalink) Old Mar 20th, 06, 11:13 PM
Basically, when the torque converter clutch (TCC) solenoid goes bad the converter can act a couple of different ways. Either the torque converter clutch does not lock-up AT ALL which isn't a huge problem. Fuel economy and performance will suffer but it won't kill the engine. OR, the converter clutch will "lock-up" and not release. This can kill the engine when coming to a stop. It has a feeling similar to driving a manual trans car and not pushing in the clutch when coming to a stop, thus killing the engine. The converter will usually release when the engine quits running and the car will start right back up. If the TCC solenoid sticks and stays "locked-up" it will act like you are trying to start a car in gear, and can kill the engine when shifting from Park or Neutral to drive or reverse.
Beat it to Fit, Paint it to Match!
Johnny B is offline
