94 3.4l v6 5 speed camaro - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 21st, 06, 08:00 AM Thread Starter
what could be causing these problems hesatatoin,lacks power,and we have had it in the shop they have replaced the injecters with accel 17lb injecters,replaced the PCM,crank and cam sensors,coil packs, plugs and wires and checked the wiring harness;still did not run right after it came from the shop.We checked the new spark plugs and one was cracked. we replaced it and it ran good for 2 days then ran the same as before.and when ran hard it sometimes blows a plug wire off.any ideas?
elizabeth trende is offline
post #2 of 2 (permalink) Old Mar 21st, 06, 08:42 AM
Steven
Re: 94 3.4l v6 5 speed camaro
Some ideas ... I see no mention of fuel supply like fuel filter and/or fuel pump to insure that you are getting adequate fuel supply... Also check air intake for clean filter and to insure that there is no obstruction there... A clogged cat/exhaust will also give you problems and kill power ... Lastly, check connectors on sensors to see if something may be getting intermittent/faulty signal ... Hard to come up with reason why plug wire blows off ...maybe th end needs to be "squeezed" a little for a tighter fit ...
sdtsdt is offline
