I should have taken courses.... - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 24th, 06, 04:34 PM Thread Starter
Keith
Send a message via AIM to heatsinker
Ok, bought the car like 3-4 weeks ago and all was great. Suddenly I jump in to go for a drive and........click/click nothing. Try a jumpstart and after a long time she finally turns over. Let it run a while, shut it off and nothing again. I am thinking battery or altenator.........sound right?
Keith
1967 L-35 SS
heatsinker is offline
post #2 of 6 (permalink) Old Mar 24th, 06, 04:57 PM
Re: I should have taken courses....
It sounds like the battery has gone fatally dead. You can take the battery in to a parts store and have it tested. If you jumpstart the car, take off the cables and it continues to run fine, it sounds like the charging system is working fine. Take a multimeter or look at your volt guage if you have one, it should read 13-14 volts if the alternator is good. Less than 12 volts and it is bad.
SoCalFirstGen is offline
post #3 of 6 (permalink) Old Mar 24th, 06, 05:00 PM Thread Starter
Keith
thanks
Keith
1967 L-35 SS
post #4 of 6 (permalink) Old Mar 25th, 06, 07:06 AM Thread Starter
Keith
Thanks again........Bought Battery and altenator, Installed battery and tried it, started no problem. Guess I now have a spare altenator if it ever goes bad.
thanks again,
Keith
Keith
1967 L-35 SS
post #5 of 6 (permalink) Old Mar 25th, 06, 02:03 PM
Steps
Get a hydrometer...couple bucks at the local store...check SG in each battery cell, if 1 or 2 cells are markedly diff to the rest...replace battery.
At the same time check alternater out puts...just to make sure it wasnt the alternator that killed the battery.
Steptoe is offline
post #6 of 6 (permalink) Old Mar 25th, 06, 07:17 PM
Check out the thread https://www.camaros.net/forums/showthread.php?t=77517 titled "I don't really know whats hapeening!". I posted a general proof of performance you can do to identify charging / battery problems.
dnult is offline
