Key position in ignition is critical? - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 28th, 06, 05:12 PM Thread Starter
My camaro will either start or not depending on how I apply pressure on the key in the ignition. It takes some force applied to the key so it twists to get the starter to crank over. I was fiddiling around and found the way to get her to start. Should I get a new switch so I don't use two hands to turn the key so it bows correctly in there?
68bbconv is offline
post #2 of 6 (permalink) Old Mar 28th, 06, 05:42 PM
Re: Key position in ignition is critical?
yes
post #3 of 6 (permalink) Old Mar 28th, 06, 07:13 PM
It would be a good start......No pun intended.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 6 (permalink) Old Mar 28th, 06, 10:47 PM
Steps
1/ drop the column 2 bolts under dash, check that the electic switch mounted on the column 1/2 way down is located corectly.
2/ if u turn the part of the column behind the steering wheel by hand does this make it easier? If so it maybe the adjustment under the car from the end of the column in the engine compartment to the trans.
3/The column has not been re assembled coorectly
4/ Also going with the above (3) the steering wheel has been removed by a wack instead of a puller, shortening the steering shaft.
There is a thread by me about these problems and how to about a month ago
Run a forum search 35" or 35 inch i think will find it
Steptoe is offline
post #5 of 6 (permalink) Old Mar 29th, 06, 04:06 AM
Steptoe, his ign switch is on the dash, not in the steering column. You are forgiven.
I had a similar problem like this and I was able to disassemble the switch and clean the contacts and lube it with dielectric grease, works great.
post #6 of 6 (permalink) Old Mar 29th, 06, 10:54 AM
Steps
LMAO
We have a saying down here
"Opening your mouth to change feet" lol
The biggest thing to kill an ignition switch is a heavy bunch of keys.
Take switch out and take up to the local lock smith, for a few cheap bucks they will redo the tumblers and stuff inside
Steptoe is offline
