Hideaway headlights - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 28th, 06, 06:37 PM Thread Starter
Hideaway headlights
Hi everyone, this is my first post. I have a 69 Camaro that has the vacuum operated hideaway headlights. The headlight doors do not work. I have replaced all the hoses and they still don't work. How should I go about trouble shooting the system to locate the problem? Thanks!
Basser is offline
post #2 of 3 (permalink) Old Mar 30th, 06, 04:18 PM
Re: Hideaway headlights
Look in the tech reference section of this site for the system hose diagram. Then check for vacuum at the actuators. the vacuum should change between the two hoses that are connected to the actuators as you cycle the headlight switch. if it does then suspect a mechanical problem. if not, back track up the system and hoses to determine where the vacuum is not flowing properly.
sorta like electrical system diagnosis.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #3 of 3 (permalink) Old Mar 30th, 06, 05:29 PM
bruce
you may also have a problem with low vacuum at low engine speeds. I know mine does; do they close when rpms are elevated to 3 -4k? If so, you may want to check into placing a vacuum check valve to prevent "bleed off"...
70 cuda 383
69z28/rs
03 z06 vette
05 srt-10 505ci quad cab "yellow fever"
"its never fast enough"
brucelbryan is offline
