no fire or fuel with new engine? - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 30th, 06, 12:33 PM Thread Starter
i have a 95 camaro and it is automatic. i just put in another motor i had out of a 94 and i changed the transmission to a 6 speed. everything is hooked up fine and it turns over fine. the problem is there is no fire and no fuel. has anyone changed their auto trans to a standard before? i don't know if that has anything to do with it. i used the copmuter, wiring harness, motor, and trans out of a 94 and put it in the 95. please help
camarokrazed20 is offline
post #2 of 6 (permalink) Old Mar 30th, 06, 04:13 PM
Steven
Re: no fire or fuel with new engine?
My first guess would be the VATS system. I suspect that your 95 key is a different resistance than what the 94 was using.
sdtsdt is offline
post #3 of 6 (permalink) Old Mar 30th, 06, 06:09 PM Thread Starter
if it was the vats then it wouldn't even turn over then right>?
post #4 of 6 (permalink) Old Mar 31st, 06, 05:51 AM
Steven
Yes, it would turn over ... BUT, the vats system will disable the fuel flow ...
sdtsdt is offline
post #5 of 6 (permalink) Old Mar 31st, 06, 11:13 AM Thread Starter
but when i turn the key on the security light goes off
post #6 of 6 (permalink) Old Mar 31st, 06, 12:05 PM
Steven
There is possibility that something else may be at fault here, but, if you have doubled-checked everything else, then I am back to VATS.
Here is a link with a clearer explaination:
http://www.camarosource.ca/new/new_l...al/vats101.htm
The Computer expects to see a specific resistance value and the key/ignition has to provide that value. Since you have motor/computer from one car, and key/ignition switch from another, there is a good chance you could have a resistance mismatch ... Can you get the ignition key from donor car??? Then you can measure the resistance in the 2 chips, and, if different, you can get a replacement key cut to match your current key, BUT, with a resistance value used in the donor car ...
sdtsdt is offline
