Disaster? - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 1st, 06, 11:07 AM Thread Starter
Lars
67 Sinner's Avatar
Unhappy Disaster?
I need help!
I don't remember the word, but it's the axle between the transmission and the rear-axle..anyhow, the yok and the thing that connects the mentioned axle and the rear axle, slams into the floor of the car when I hit the throttle. is it worn out suspension, or are all hopes gone ? Big thanks
67 Sinner is offline
post #2 of 9 (permalink) Old Apr 1st, 06, 11:11 AM
Re: Disaster?
Welcome to Team Camaro!
That thing would be the driveshaft...
You need to crawl under and start looking at thing like springs and shocks and stuff. You may have broken a spring. Jack the car up and support it by the rockers so the springs and rear axle hang free, and see what you see. Could be just saggy springs. I had a '67 once that put one of the front spring eyes right thru the backseat!!!
post #3 of 9 (permalink) Old Apr 1st, 06, 11:21 AM Thread Starter
Lars
67 Sinner's Avatar
Re: Disaster?
wow! thanks for quick answer!the car has monoleaf springs and I have installed adjustable air ride to see if it will make the suspension harder.since norway is so snowy, and my car is a summer-cruiser, I have not tried the new air ride, but will adding leafs help?
Newbie from the North
'67 Camaro 350 / 350 (part RS-clone)
post #4 of 9 (permalink) Old Apr 1st, 06, 11:42 AM
Re: Disaster?
let's do some checking first.
How long has it done this?
This is not something a Camaro suspension in good condition does, unless you have big power AND big tracion, and even then wheelhop is more likely.
Check for stuff that is broken.
post #5 of 9 (permalink) Old Apr 1st, 06, 01:29 PM Thread Starter
Lars
67 Sinner's Avatar
Re: Disaster?
I bought the car a year ago, and it has always done this.but only when i really hit the throttle.in gentle acceleration, it works fine. I know that a rubber"bumper" is worn out.a rubber thing that sits above the rearaxle-house..I do not have big power nor traction.it's like the car "sits down" on the rear end when I hit it.
post #6 of 9 (permalink) Old Apr 1st, 06, 02:06 PM
DjD
DjD's Avatar
Re: Disaster?
Sounds like a broken transmission mount to me... Give it gas, the engine torques and lifts the tail of the trans off the crossmember...
Most likely a broken suspension part would result in the car sitting funny, not going straight and/or bouncing over bumps...
...Dennis
DjD is offline
post #7 of 9 (permalink) Old Apr 1st, 06, 02:51 PM
Keith
Send a message via AIM to 69mkitmine
Lightbulb Re: Disaster?
Yeah, what he said, this has been my experience. All in favor?
Keith
1969 V8
69mkitmine is offline
post #8 of 9 (permalink) Old Apr 2nd, 06, 09:12 AM Thread Starter
Lars
67 Sinner's Avatar
thanks
I might have discribed the problem in a messy way, my english isn't great..
It seems like the car sits down and the yok and driveshaft hits the ground and then the car.but I have not checked the transmission-mount for damage.
what shall I look for?should eveything be tight?
post #9 of 9 (permalink) Old Apr 2nd, 06, 09:21 AM
Re: Disaster?
For the transmission mount, jut put a jack under the trans case and lift the trans a bit and make sure the mount does not separate.
I'm still thinking broken springs, or possibly collapsed and rusted out torque boxes. Look where the front of the leaf springs attaches to the body. They can break where the front of the spring wraps around the bushing. It will continue to support the weight of the car, but under torque may separate. If you support the car by the body (rockers) and let the axle hang, you should be able to inspect that area and see the problem.
If there's nothing broken, you might replace the springs. They could easily be that old and saggy.
