1969 camaro clutch pedal - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 5th, 06, 04:52 AM Thread Starter
How do I tell on a used clutch pedal setup I am looking at if it is for a 1969 camaro or for the 67-68 camaro? I have heard they are different? Is it the hole locations in them? Thanks for any help
Spirit1 is offline
post #2 of 4 (permalink) Old Apr 5th, 06, 06:55 AM
Charles
Re: 1969 camaro clutch pedal
on top of the pedal bracket there should be a date code stamped into the metal. at least there was for the 2 69' set-ups i had.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 4 (permalink) Old Apr 5th, 06, 08:06 AM
The clutch pedal is the same all three years. The mounting bracket and the brake pedal are what's different 67-68 and 69. If you have an existing 69 mounting bracket in good shape, they are the same whether the car is manual or automatic. You just slip out the auto brake pedal and slide in the two pedals.
Rick's online catalog ( www.firstgen.com ) should have some good pictures of the bracket and pedals.
If you're swap meet hunting, yes the date is stamped in the top.
Eric
Eric Kammerer is offline
post #4 of 4 (permalink) Old Apr 5th, 06, 08:24 AM Thread Starter
Thanks for the help! I have a automatic pedal in my car now. What is different on the clutch/brake pedal?
I just noticed Rick's sells a brake clutch pedal for 67-68 and a seprate set up for a 69.
Spirit1 is offline
