my camaro jerks - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 8th, 06, 10:00 PM Thread Starter
my camaro jerks
Hello, I have 89 camaro. I replaced starter and changed oil for while ago. But, today my car started to jerk when I drive. fuel pump or engine problem?? If you have any idea, please let me know. thank you
oldcamaro is offline
post #2 of 10 (permalink) Old Apr 8th, 06, 10:51 PM
Re: my camaro jerks
Are you getting any trouble codes from the ECM, before the car cuts off or starts to jerk?
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 10 (permalink) Old Apr 9th, 06, 04:37 AM
Harry
dawg's Avatar
Re: my camaro jerks
mine jerks alot too !
I just gotta keep a steady foot on the gas!
(joke)
It could be any number of things wrong with your camaro.
youll need to do some more troubleshooting so that we have more info.
434 stroker
US Navy retired
dawg is offline
post #4 of 10 (permalink) Old Apr 9th, 06, 06:25 AM
Re: my camaro jerks
is it a hesitation or a pulling foward kinda jerk????? Need more details
twistedx11 is offline
post #5 of 10 (permalink) Old Apr 9th, 06, 09:52 AM Thread Starter
Re: my camaro jerks
Thank you for your responds. I think I have pulling foward jerks. It happens, especially when I hit the gas. A tachometer jerks too.
sometimes, it doesn't jerk but it usually jerk
post #6 of 10 (permalink) Old Apr 9th, 06, 09:20 PM
Re: my camaro jerks
It sounds like you might have a transmission problem (Trans mount) or a drivetrain problem. Check your U-joints and see if they are loose.
post #7 of 10 (permalink) Old Apr 11th, 06, 03:49 AM
Re: my camaro jerks
check out the fuel filter back by the tank probably about a foot and a half from the tank toward the moter , if thats not it then pull the tank and check the strainer on the fuel pump , Also if those aren't your problem you should have your Mass air flow sensor checked and also your throttle possition sensor which is on the throttle body itself and has a three pronge plug its on the passengers side of the throttle body. Bad plugs , wires and distrbiutor cap will cause that too. Hope this helps
post #8 of 10 (permalink) Old Apr 11th, 06, 12:38 PM
Patrick
Re: my camaro jerks
My wife says there is a jerk in my camaro also!
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #9 of 10 (permalink) Old Apr 12th, 06, 01:25 PM
Kevin
SixtyAte's Avatar
Re: my camaro jerks
It sounds like a loose coil wire or a bad ground to me.
Kev
SixtyAte is offline
post #10 of 10 (permalink) Old Apr 16th, 06, 04:11 PM Thread Starter
Re: my camaro jerks
The problem solved. A problme was some of ignitoin wires. I replaced them, now it doesn't jerk anymore. Thank you.
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
69 Camaro Trike edd Gordon Bench Racing 0 Mar 11th, 06 11:53 AM
Vintage Camaro [email protected] Camaro Nationals shaugs Bench Racing 0 Nov 23rd, 05 07:36 AM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
Finding the good 69 Camaro. hemi.42 Tag Team 2 Jul 6th, 04 06:40 AM
