fuel delivery problem - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 9th, 06, 10:27 AM Thread Starter
i have a 91 5 speed, 305 tbi. i am getting no fuel to the injection system. i replaced the fuel pump, filter and fuel relay switch. i am getting no power to the pump. any suggestions?
91 5stbi is offline
post #2 of 4 (permalink) Old Apr 10th, 06, 03:47 AM
Re: fuel delivery problem
Empty tank.
Blown fuse.
Open power supply wire in harness.
Open ground wire/circuit at fuel pump assembly/tank.
Sunken socket in connector(s).
No power to relay due to broken wire or bad driver in ECM.
Fusible link at starter solenoid stud burnt/broken.
Fuel pump should come ON for two seconds when ign ke is turned to IGN position. After this event, Start signal should energize the relay, via ECM, and, in a parallel path, oil pressure switch should close and provide another path to energize fuel pump. Oil pressure sensor is underneath distributor.
post #3 of 4 (permalink) Old Apr 10th, 06, 05:48 PM
Darrell
when you turn ign.on pump should get power for about 3 seconds,if not ck pump relay
Seneca SS is offline
post #4 of 4 (permalink) Old Apr 15th, 06, 10:10 AM Thread Starter
i heard that if my oil pressure sensor was faulty that my fuel pump would not energize. is that true?
91 5stbi is offline
Edelbrock carb problem? fuel drip, hesitation and backfire -please HELP! mr69 Troubleshooting 6 Aug 7th, 11 07:06 PM
Autometer Fuel Gage Problem jacket Electrical & Wiring 4 Nov 6th, 05 02:42 PM
fuel tank or gauge problem? norcalcamaro Engine 3 Oct 28th, 05 09:09 AM
fuel pressure problem camaro man Engine 21 Jul 20th, 05 05:07 PM
Fuel Injection problem Leviathan Engine 3 Aug 30th, 04 01:38 PM
