Starter not disengaging... - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 9th, 06, 06:28 PM Thread Starter
Well as soon as I got my carb problem fixed now this. This afternoon the starter would not disengage even after I had pulled the key out. I have tried putting in shims (1/32 on each side) and replacing battery with one just off the charger . Problem still there. The only way to get it to stop turning over is to pull the pos. cable. After removing cable I can put it back on and it might start 2-3 times with no problem. I plan on removing the starter and seeing if it still does it on the ground. If it works fine on the ground does that mean the starter is good?
KC406RS is offline
post #2 of 9 (permalink) Old Apr 9th, 06, 08:02 PM
Smile Re: Starter not disengaging...
Sounds like the solenoid is not working as it should. The contact inside the solenoid is probably badly burnt. I would try that before investing in a new starter. I think i paid about 10-15 bucks the last time i bought one. Hope this helps.
67 Plain Jane is offline
post #3 of 9 (permalink) Old Apr 9th, 06, 09:03 PM
Check the positive battery cable going to the solenoid and see if it slipped making contact with the switch terminal. If that's okay then replace the solenoid as Tom said.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 9 (permalink) Old Apr 9th, 06, 10:28 PM
Rob.
Heres some more on starters I posted on another site.
Go down to a auto parts store and tell them you need a check pin for your starter and the instruction sheet that goes with it. If you have a auto zone there they will give it to you for free, auto zone puts the instruction sheet and pin in the box with rebuilt and new starters. If any auto parts store can't furnish you with one then somethings wrong.
This pin is round and about four inches long .125 ( 1/8'' ) thick.
Now pull the inspection cover so you can see the starter drive and teeth on the flywheel, carefully take the pin and instruction sheet and see if the pin will slide between the armature shaft and a tooth of the ring gear. The instruction sheet will show you how to shim it and where (get a bunch of shims you'l need them) you can take back what you don't need.
This might take a few times unbolting and reshiming but be patient because if you shim it right it will be quieter and will last a long time, because if you don't you'l be replacing starter drives and sometimes the ring gear (flywheel) gear, been there on ring gears.
I don't know if this is your problem, but after you mentioned shims, I thought I would run this by you, good luck.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
1969ss is offline
post #5 of 9 (permalink) Old Apr 10th, 06, 06:12 PM Thread Starter
Turns out it was the solenoid, and only $10 what a deal.
KC406RS is offline
post #6 of 9 (permalink) Old Apr 10th, 06, 07:30 PM
Glad it was simple and cheap. Thanks for posting what you found. Sometimes these old cars can drive you up the wall, but god i love 'em.
post #7 of 9 (permalink) Old Jun 1st, 08, 10:30 PM
I'm having the same exact symptoms. Today I finished installing a new clutch assembly and rebuilt transmission. I've been working on this over the last few months. I did install a new starter and was careful to check the flywheel spacing prior to putting the bellhousing back on. After getting everything back together I wanted to crank the engine without the coil wire installed to check out the starter. It cranked beautifully and everything seemed OK, as I turned on and off the key many times.
However, after making some more checks I turned the key on and off and the started kept going. The only way I could stop it was by disconnected from the battery. I can then reconnect the battery and have the same situation once I turn the key to the start position.
My question - I'm assuming the starter will stay engaged as long as the solenoid is enaged, regardless of the key position. Is this true? I'll be pulling the started out tomorrow to check the solenoid.
ColoradoZ28
ColoradoZ28 is offline
post #8 of 9 (permalink) Old Jun 2nd, 08, 04:29 AM
Originally Posted by ColoradoZ28 View Post
My question - I'm assuming the starter will stay engaged as long as the solenoid is enaged, regardless of the key position. Is this true? ColoradoZ28
True.
post #9 of 9 (permalink) Old Jun 2nd, 08, 08:24 AM
A bad ignition switch can cause this same problem.
deerhunter is offline
BB Starter Swap Help SS 396 Engine 3 Sep 28th, 05 08:08 PM
Starter issues with Proform starter X33camaro Electrical & Wiring 4 Aug 22nd, 05 08:44 PM
Starter Problems NRMEDIC984 Engine 3 Jun 30th, 05 04:55 AM
Starter Tech JimM Electrical & Wiring 2 Sep 21st, 04 09:41 AM
starter teeth problem. flywheel grinding Marc Engine 6 Jul 7th, 03 01:53 AM
