Stick Shifter? - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 12th, 06, 06:03 AM Thread Starter
Cool Stick Shifter?
I have a 67 which I recently replaced the powerglide with a TH-350. The handle inside the car on the console that I grab to take the car out of park and into gear....what is that acutall called? Anyway...this is "T" shaped with a black rectangle button in the middle of it that you depress. As I was taking the out of Park the "Black Button" just popped off revealing what appeared to be a rod that ran down the middle of the handle. I have checked with several different parts stores and they only have the black button for sale and it looks like I will need the entire assembly. Does anyone know where I might be able to purchase this item and can you PLEASE tell me what to properly call this thing!? Thanks in advance for any help you can provide.
soonerdean is offline
post #2 of 7 (permalink) Old Apr 12th, 06, 11:27 AM
Re: Stick Shifter?
I call it the Shifter or T- handle/shifter. You should be able to pop the cover back on top of the shifter without buying a new one. If the cover is broken, then you will need to replace it. You can not buy the whole shifter since they are not reproducing them at this time. The only other thing would be to locate a good used one, if you need to replace the shifter.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 7 (permalink) Old Apr 12th, 06, 01:29 PM
Kevin
SixtyAte's Avatar
Re: Stick Shifter?
The parts or whole shifter is available. I just did a Google search and found links to parts and a whole shifter. An example site...
http://www.shiftworks.com/camaro.htm
Kev
SixtyAte is offline
post #4 of 7 (permalink) Old Apr 12th, 06, 10:15 PM
Re: Stick Shifter?
I checked the link out.....it only shows a picture of the shifter with the parts that go to it. It doesn't say that the shifter is available unless I missed something.
post #5 of 7 (permalink) Old Apr 13th, 06, 03:21 AM
Kevin
SixtyAte's Avatar
Re: Stick Shifter?
Dave...
I stand corrected. Geesh... well atleast I was correct on the parts
Kev
SixtyAte is offline
post #6 of 7 (permalink) Old Apr 13th, 06, 02:09 PM Thread Starter
Re: Stick Shifter?
Thanks for the help guys...I contacted shiftworks and they did have the "acutator" I needed and they were quite friendly. I'm on the road again.
post #7 of 7 (permalink) Old Apr 13th, 06, 02:21 PM
Kevin
SixtyAte's Avatar
Re: Stick Shifter?
Glad you were able to get the parts needed.
Kev
SixtyAte is offline
shifter problem or trans? 67ragtp Transmission & Driveline 9 Dec 18th, 05 06:21 AM
1967 Shift Stick Tom Laferriere Transmission & Driveline 21 Sep 30th, 04 10:31 AM
hurst 1/4 stick shifter in a first gen w/console 67FREAK Transmission & Driveline 4 May 13th, 03 08:48 AM
TREMEC 5sp custom shifter available! mjpell Engine 2 Feb 10th, 03 04:28 PM
B&M Pro Stick shifter in a 69... RFrenette Tech 2000 5 May 5th, 01 09:56 AM
