Bad vibrations - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 14th, 06, 05:37 AM Thread Starter
Bad vibrations
Have an 2.8 V6 '87 LT auto that suffers from severe vibrations as it goes up the rev range. Vibrations drop off after auto box shifts, then pick up again as the revs rise before the next gear change. Doesn't do it when revved and not moving. So it has to be something to do with a part which moves at the same speed as the engine when the car is moving. Have had the engine and transmission checked twice to no avail. Mechanic reckons the drive shaft and rear diff are fine. Anyone out there got any ideas or experienced something similar? Am getting more and more frustrated by this because the vibrations are getting so bad it feels like the car is about to shake itself apart.
Thanks.
2507ben is offline
post #2 of 3 (permalink) Old Apr 14th, 06, 06:07 AM
Re: Bad vibrations
Maybe simple like you threw a wheel weight off. Can you feel it through the stering wheel?
Far69 is offline
post #3 of 3 (permalink) Old Apr 14th, 06, 06:09 AM Thread Starter
Re: Bad vibrations
Nope, steering is fine. The vibrations seem to come right up through the body of the car at the rear end, which is why I initially thought either the driveshaft or rear diff might be the problem.
2507ben is offline
Bad window switch or bad motor Meanchicken Electrical & Wiring 2 Oct 3rd, 05 05:41 AM
Things are BAD BAD BAD rich pern Bench Racing 1 Aug 30th, 05 10:04 PM
torque converter bad? topdown69 Transmission & Driveline 2 Jun 28th, 05 11:30 AM
Bad Vibrations tmc1stgen Transmission & Driveline 8 May 8th, 05 06:04 AM
Even The Top Of The Line Has Its Bad Days bigdawginva Electrical & Wiring 0 Apr 21st, 05 05:19 PM
