no power to fuel pump - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 16th, 06, 06:26 AM Thread Starter
i have 1985iroc 305tpi put brand new fuel pump and sending unit have power under car wher tank plugs into body still pump wont turn on help please.......also can somone tell me whear is fule pump relay thanks
louis manco is offline
post #2 of 3 (permalink) Old Apr 16th, 06, 07:07 AM
Re: no power to fuel pump
your relay switch should be located on the drivewr side firewall. there is 3 connections next to your wiring harness in the engine bay that snap together. if their is no power to your pump, check the relay switch, fuse, oil pressure sending unit all wires connected to the system. this just happened to my 305 tbi 91 and it was my oil pressure sending unit. go figure. good luck
91 5stbi is offline
post #3 of 3 (permalink) Old Apr 16th, 06, 07:30 AM Thread Starter
hay thanks i will try that anlet ya no
fuel pump & fuel cell suggestions needed bills68camaro Performance 3 Apr 3rd, 06 05:05 PM
Fuel Pump Line Fitting?? 67 Convertible Engine 4 Apr 20th, 05 04:46 AM
Which electric fuel pump? paul1969 Performance 6 Mar 22nd, 03 02:28 PM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 04:36 PM
1969 CAMARO BIG BLOCK POWER STEERING PUMP DAMCDO Tech 2000 3 Dec 31st, 99 08:48 AM
