67 Wont Start - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 22nd, 06, 04:17 AM Thread Starter
67 Wont Start
My car was OK last week. Now the starter works OK but I receive only 10 Volts in the distributor. (To low to start) but 12.4 volts on starter. If I place a wire from the windshield wiper motor to teh distributor, it starts.
My car has electronic ignition.
What is possibly happening?
POCKER is offline
post #2 of 2 (permalink) Old Apr 22nd, 06, 05:03 AM
Re: 67 Wont Start
Theres a resistor wire between the ignition switch and the ignition coil, in a stock wiring haqrness designed to lower running voltage to the coil to about 9 volts to lengthen the life of the points. Most electronic ignitions, especially mallories require you to bypass this wire to get a full 12V to the coil. There should also be a yellow wire running up from the R terminal on the starter to the coil, that will provide 12V from the starter directly to the coil during starting.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
Opions on value of 67 396 SS ? 67 owners please read ! 69 350 SS Bench Racing 18 Apr 21st, 06 07:57 PM
Pictures of correct OEM Gills, lights, 67, 68 Camaros ToyzShopGary Body Shop 5 Jan 15th, 06 07:26 AM
intermidiat no start crasher Electrical & Wiring 0 Jul 30th, 05 09:36 PM
My camaro won't start Broden89rs Tech 2000 5 Sep 27th, 00 02:42 PM
