97 ss o2 sensor ??? - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 22nd, 06, 09:27 AM Thread Starter
97 ss o2 sensor ???
Hello everyone I am new to the board and need your advice. I have a 97 camaro ss convertible with the 6 speed trans and the ram air lt1 engine. I have owned the car about 6 mounths and it has always had a high idle around 1100 rpm no matter what temp. but still ran and performed well. Now when it starts to warm up it starts miss fireing under aceleration and the check engine light is on and after shut down you can smell gas. I took it to the local parts store and had the codes read which said bank 2 number 1 o2 sensor. The car has new wires plugs and opti. I want to make sure I am changing the right part for the problem this sensor is a real bummer to get to and remove. Thanks for your help
duckman1965 is offline
post #2 of 2 (permalink) Old Apr 22nd, 06, 09:41 PM
Re: 97 ss o2 sensor ???
It might be because your engine is getting too much fuel and running rich. The 02 sensor doesn't have to be bad because the ECM kicked out the code. It is just reading the rich fuel mixture.
Camaro buds until the end!!!
Camaro Dave is offline
temperature sensor DDD Camaros.net Site Help Discussion 0 Nov 14th, 05 06:12 PM
Temp Sensor? 4U 2 NV Engine 2 Feb 6th, 03 05:52 PM
Map Sensor wadesters Troubleshooting 2 Mar 8th, 02 02:42 AM
3/8" NPT Temp Sensor that will work in a 67 Torch Tech 2000 1 Jul 13th, 00 03:05 PM
Pertronix Lobe Sensor Ignitor mike brown Engine 2 Nov 25th, 99 08:02 AM
