Tachometer problems - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 22nd, 06, 04:30 PM Thread Starter
B
Tachometer problems
gone over this before, but maybe has someone has some new ideas....
my 69 RS has the 396/375 w/console guages Tach(my car was orginally a RS V-8 Van Nuys car, no stinking codes), now with a well-worked 350[383]), so it's probably aftermarket. It's a TH350, so no big rush, but it annoys me it isn't working...the tach wire is connected to the coil. I pulled the tach out out and can't see that anything is disconnected, but only one main thing is attached to it anyway so there isn't much to be disconnected anyway.
I know the OER RS headlight switches are problematic, are the OER tach's also troublesome?
Formers: 1969 RS 350, 700HP 1967 Flash-in-a-pan Firebird 400, 2002 Z28 M6 1SC/1SZ
SnakeEyes is offline
post #2 of 3 (permalink) Old Apr 22nd, 06, 04:37 PM
Re: Tachometer problems
my oer tach has been fine, exceot for needing a filter to work properly with my electronic ignition, course my 68 tach is a bit different than yours.
The tach should have 3 connections. Ground, ignition switch power, and the coil signal whiuch should be connected to the negative side of the coil.
post #3 of 3 (permalink) Old Apr 22nd, 06, 05:42 PM Thread Starter
B
alright, maybe my memory is sketchy, I'll pull it out again and check it out...again.
Tachometer DDD Electrical & Wiring 0 Jan 6th, 06 10:49 PM
Intermittent Starting Problems Mike67RS Electrical & Wiring 8 Aug 29th, 05 11:18 PM
Goodmark Quarter Panel Problems!!!! Liveinaz Body Shop 7 Jun 28th, 05 08:10 PM
Tachometer Problems Gold 67 Electrical & Wiring 0 Jan 26th, 04 01:03 PM
MSD PROBLEMS RAY NORLIN Troubleshooting 3 Oct 9th, 00 02:40 PM
