92 Camaro RS stalls out immediately - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 23rd, 06, 11:55 AM Thread Starter
This is my dad's camaro. It is a basically bone stock 92 camaro RS with a 305 mileage around 50k. The car will start and run with a few cranks but will stall out after about 5 seconds. It will start up the same way but will run a little bit (seconds) longer each time. It does not respond to the throttle at all and he has changed alot of the major sensors. He told me all the things he's replaced but I can't remember them all. The car does sit alot and sees very little use. He does start it regularly but it seldom leaves the garage. He's changed the oxygen sensor and computer module as well as the distributor cap. He inspected the egr valve and said it seems to close fine. Any ideas will be greatly appreciated. I can get more info from him as needed.
EdandStacy is offline
post #2 of 8 (permalink) Old Apr 23rd, 06, 07:00 PM
Re: 92 Camaro RS stalls out immediately
Sounds like the fuel pump is giving up. Have you checked the fuel press? When you turn the key to the on position you should hear a hum until the pump gets the system up to press. Hope this helps.
67 Plain Jane is offline
post #3 of 8 (permalink) Old Apr 23rd, 06, 07:03 PM Thread Starter
I thought that myself. He started it for me the other day and I thought I could hear it running after it stalled out. We'll have to check that out. What is the best way to test it? Could it be a pump relay?
post #4 of 8 (permalink) Old Apr 24th, 06, 03:49 AM
If you hear the fuel pump running, then there is nothing wrong with fuel pump relay.
There should be a Scrader valve on the fuel rail for pressure testing. TBI = 9-13 PSI, MFI = 45-55 PSI.
It may be flooding out due to inoperative IAC or its ancillary place equipment.
Does the engine fast idle when cold?
Does the rpm remain the same when A/C or Defrost is selected?
Does the rpm remain the same when a gear is selected?
Same with headlights turned on.
If the IAC isn't working, or its ports in the plate are carboned up, the engine will run rich. The Idle Air Control is a controlled vacuum leak on this is how engine idle rpm is set. The engine must fast idle. If it doesn't, remove a spark plug and check for wet electrodes.
Don't be afraid to hold throttle plates open when starting, same method used in starting a flooded carbureted engine can be applied to a flooded EFI engine.
post #5 of 8 (permalink) Old Apr 24th, 06, 04:31 AM Thread Starter
The IAC has already been changed. We will have to test the fuel pressure next time we are out. Initially the only code that was set was O2 sensor but that is most likely because of how it is running. We are going to take another look at the EGR valve. It will run longer each time you start it pretty much as it warms up. The idle is high and seems normal except maybe for a slight mis. When warmed up after starting many times the idle is eratic and it surges. It starts almost exactly the same way each time 2 or 3 cranks.
post #6 of 8 (permalink) Old Jun 14th, 07, 06:56 PM
pour gas in carb and see if it runs as long as u pour gas in
yea its dangerous but that will seperate spark from fuel problems
bookin dano is offline
post #7 of 8 (permalink) Old Jun 15th, 07, 04:24 AM
no carb on that car, dano...change the fuel filter...could be that there isnt enough volume getting through the filter to support the engine...
kustomwerker is offline
post #8 of 8 (permalink) Old Jun 20th, 07, 10:07 PM
okay pour gas in the throttle body
sorry for the mistake
guess im showin my age
Considering selling my Camaro Hrod382 Bench Racing 20 Feb 1st, 06 05:15 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
Camaro Generations TJS69 Bench Racing 1 Jul 27th, 05 12:11 PM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
Engine Stalls in 93' Camaro rbks50 Troubleshooting 3 Apr 10th, 04 06:56 AM
