Speedo and service engine soon light............ - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 24th, 06, 09:02 AM Thread Starter
New guy here so please be gentle...............
Driving yesterday and my noisy, "chirpy" speedo stops working after I hit a pothole. About one minute later the service engine soon light comes on. The car seems to be running fine. Is it possible that the light has come on due to the speedo failing ?
Also, if the speedo has been "chirping" for quite a while and the needle bouncing, is my problem most likely behind the gauge or down at the tranny ?
This car is a '89 RS with a 2.8 v6. Thanx for any advice !
sixstringer76 is offline
post #2 of 2 (permalink) Old Apr 24th, 06, 10:18 AM
Re: Speedo and service engine soon light............
Yes, you probably got a code from the VSS (vehicle speed sensor). I would check the speedo cable first. It is common for them to break in the third gen Camaros.
Camaro buds until the end!!!
Camaro Dave is offline
