93 Camaro Wipers Go REEEAALLY slow, any ideas? - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 24th, 06, 06:52 PM Thread Starter
Exclamation 93 Camaro Wipers Go REEEAALLY slow, any ideas?
Has anyone else experienced this problem?:
Lately when I turn on my wipers they respond very slowly as if very weak and now today they pretty stopped entirely. If I leave them on they will occasionally jolt a little bit, same thing happens if I turn them OFF. Very strange. Think it's the motor? The switch? a wire short? Anyone else had this?
Subtlesustain is offline
post #2 of 7 (permalink) Old Apr 26th, 06, 10:18 AM Thread Starter
Re: 93 Camaro Wipers Go REEEAALLY slow, any ideas?
Update: I turned on my car again yesterday and the wipers returned to their normal down position. However, the wipers still move very slowly, I'm thinking maybe it's the switch. Does that sound right?
post #3 of 7 (permalink) Old Apr 26th, 06, 11:55 AM
Steven
Use a multimeter ( can get one under $10 ..WalMart, Harbor Tools, etc ) to measure volts at wiper motor connection ... If you are getting 12 volts ( with key on ) or more ( with engine running ), then chances are that the wiper motor is the culprit. If you are getting lesser volts, or even intermittent voltage, then the switch is probable .
sdtsdt is offline
post #4 of 7 (permalink) Old Apr 26th, 06, 04:31 PM Thread Starter
Thanks, that makes sense. I'll give it a try!
post #5 of 7 (permalink) Old Apr 28th, 06, 02:00 AM
gm trucks around the same years had problems with the wiper controler (its inside the wiper housing but not part of the motor) and the camaro might have had similar problems
400bird is offline
post #6 of 7 (permalink) Old May 2nd, 06, 12:14 PM Thread Starter
Smile Re: 93 Camaro Wipers Go REEEAALLY slow, any ideas?
Ok, I'm guessing it might be the wiper housing. I've been able to turn the wipers on recently, but they still move pretty slow. Is it a short or a faulty connection at the controller? Also, what's the best way to get at the wiper assembly to do this repair? Under the dash, or under the hood?
post #7 of 7 (permalink) Old May 2nd, 06, 04:55 PM
DONNIE
yes they do have a wiper controler not easy to change on a camaro
67CAMAROSS is offline
New 69 CAMARO bodies coporic Bench Racing 16 Feb 25th, 07 08:08 AM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
April 2- Camaro Day on DIYN WildBillyT Bench Racing 7 Mar 23rd, 05 01:43 AM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
Rhonert Park Camaro Results Ed Ernst Bench Racing 9 Jul 11th, 01 07:59 AM
