83 camaro with a 91 350 block - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 28th, 06, 06:16 PM Thread Starter
need some help on how to set my carb...it is a rochester q-jet and it is running really rich and when i hit the gas it hesitates and stall's out.
i tried to adjust the air fuel mix but i think i got it wrong
and also thinking off turning it into a quarter miler and need some info on how to beef the frame up as well as the rear 4 link..and the tilt colum has a bearing in it and i broke it replacing my ignition..(the one on the shaft)
now my steering wheel is wacked.i couldnt get the bearing to press all the way down the shaft....thanx (jay)
berlinettaboyz is offline
post #2 of 3 (permalink) Old Apr 29th, 06, 01:05 PM Thread Starter
Re: 83 camaro with a 91 350 block
so i guess no one has any idea's.....thanx anyway's
post #3 of 3 (permalink) Old May 2nd, 06, 07:35 PM
well if you want a 1/4 miler junk the quadra-junk and get a real carb, as far as setting it the question would be manual or electric choke?
twistedx11 is offline
69 Camaro convert 305 small block to 400 small block P0RCH Engine 4 Oct 11th, 05 04:48 PM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 11:50 AM
400 Block 350 Crank ???? bdcole_51 Engine 11 Sep 18th, 05 08:34 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
350 short block or build from scratch? Tom Ziokowski Tech 2000 3 Oct 22nd, 00 06:21 PM
