95 Camaro Fuel Problem - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 28th, 06, 08:12 PM Thread Starter
Hello, I'm new to the site and have a somewhat puzzling problem. I have a 95 camaro with a 3.4L that wont start. Now I know that it has spark because it fires on starting fluid, and I also know that the fuel pump is kicking on. There is fuel at the rails, because I removed the pressure release valve cap and pushed that down with a screwdriver and gas came out, sprayed a fuew inches or so in the air. Seemed to have descent pressure however this isn't a very accurate way to check. Any Ideas? Any help would be greatly appreciated as the vehicle is a daily driver!!!
THanks!
Sean
Seans95CaMaRo is offline
post #2 of 4 (permalink) Old Apr 29th, 06, 05:07 AM
Steven
Re: 95 Camaro Fuel Problem
Just a thought here ... Not only do you have to have fuel in the rails, but the injectors must receive the signal to fire. Are you getting a security light? The VATS system is often a culprit in a no-run situation, but if you think you have fuel pressure, then you need to determine if fuel injector are pulsing ... Look in owners manual for any relays/fuses that are associated with the injectors ???
sdtsdt is offline
post #3 of 4 (permalink) Old Apr 29th, 06, 06:23 AM
Smile Re: 95 Camaro Fuel Problem
my wifes car did the same thing. turned out to be a ground in the computer causing the injectors not to pulse.
67 Plain Jane is offline
post #4 of 4 (permalink) Old Apr 29th, 06, 09:50 AM Thread Starter
Another oddity..hooked an OBD II scanner up to it and it's not showing anything, not even turning the scanner on, any ideas there? Tried the scanner in the other car and it works fine, so I know the scanners fine. I also checked the two injector fuses in the box under the hood, both were fine.
69 Camaros on television and movies jsg1010z Bench Racing 35 Aug 15th, 10 05:28 PM
^9 Camaro Fuel Gage problem ambush904 Electrical & Wiring 0 Sep 6th, 04 05:51 AM
2004 SuperCar Reunion Labor Day weekend HawaiianCamaro Team Camaro Cruiz-Ins 1 Aug 25th, 04 08:51 PM
fuel tank removal '67 Camaro Please need a hint or 2 cavemanmoron Tech 2002 12 May 14th, 02 02:31 PM
